Does the Door skin need to be removed in order to pull full harness out???
Pulled off the entire door panel. Had to snake the harness out. It’s a bit of a pain in the balls. Just take note of the orientation of the harness and how it was routed originally. I’m sorry for the delay! I’m sure you got it done already
  • 4 weeks later...
Reviving this thread a little bit.  My 2015 Sierra thought my driver door was always open, and none of the windows would roll down from the driver module (windows would roll down from the actual door).  I looked through the wiring harness and found the green/yellow was broken so I patched that and put everything back together.  Now all the windows will roll down from the driver door except for the driver window, and now my pickup thinks the driver door is always closed.  Is the issue probably with the window motor, or I read potentially the window switch?  Trying to avoid going to the dealership to pay 5x what I could repair at home.  Thanks for the help.
Mods should add this to the pinned topics.  There is lots of good info piling up here regarding what seems like an ongoing issue with the door wiring.
  • 1 year later...
Sooo I know this thread is outdated by a few years but I was just having the same issue with my 2014 Silverado. Rear driver door ajar message, couldn't control the window from the driver controls and the dome light would stay on (as if the door was open...) anyway, after a little help from Google I found my issue and also the solution. It was a green wire that broke in the Accordion boot between the door and cab of the truck. On mine it was broke on the door end of the wiring and I had just sliced the boot open, used a wiring butt-connector to connect the ends back to one another and then used electrical tape to wrap it up and super glued the slice I made in the boot and bam. No more issues
  • 4 months later...
 Just to revive this topic once more,  I found that s3veral wires inside of the boot leading to the drivers door were frayed. I taped them and also discovered that the main hot wire (the black one) was broken off at the terminal inside of the connector.  I managed a temporary fix by jamming another piece of wire in there to hold the connection until it warmed up enough to replace the whole harness. It worked for awhile until I got a spark out of that wire. Prior to this only the driver window was affected and all others worked from the driver controls. After the short, none of the windows work from any of the controls and the door ajar light stayed on. I just replaced the entire harness and the windows still don't operate. I know I fried something, but the question is what.  The childlock buttons still work and I have control over the side mirrors. The fuse is good so I either cooked the switch or the motor/control module.  I'm not sure which to start with. The vehicle is a 2014 Silverado 1500 LT.  Any help would be appreciated.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
