Interesting Coolant Filter Find
That's why a good flush the right way is very beneficial.  Good find on that filter!
3 hours ago, Justin101714 said:
Weird, I’ve had these engine apart tons of times on too many vehicles to count and have never seen that before. I’d be curious to see what the inside of a new filter looks like. Possible paper coming apart in the filter?
Yeah I think thats why it isnt very critical to have one because to really even see it you have to trap it with a filter. And the filter looked fine a little orange from the dexcool but 100% intact for sure it didnt come apart until i ripped it open to see the inside which was showed it was sending clean filtered coolant back the reservoir.
1 hour ago, O_J_Simpson said:
You do know GM puts radiator stop leak in all trucks from the factory? That is what you are catching.
I have never heard that ever, where did you find that out at?
49 minutes ago, sdeeter19555 said:
I didn't think coolant filters used cellulose...
2012 2500hd 6.0l CCSB 4wd
The wix 24070 "coolant filter" is cellulose as well
Why try to fix what is not broken?  The older I get the more I come to realize that many of the things one does to "improve" upon what the manufacturer made can cause more harm than good or just do nothing and be a waste of money.  The coolant system works fine, their are a bunch of 14 and up models with well over 100k miles on them out there and there has not been any major ruckus over failing coolant systems.
I change my coolant every two years. I have found since having experience with the old GM "Dex-cool" that antifreeze can get corrosive over time. One of my class 8's even rotted right through a steel coolant transfer pipe. If any of you had a Gen2 Vortec 350 then you know that coolant fitting on the intake that would rot in half from acidic coolant. Thanks for letting us know there is a filter, I will swap it out next service.
could it be  from the heat ....if that's intended as a fuel filter ... it may not  like the heat of the coolant ...could it be paper  or glue particles..??
14 hours ago, Brianibew said:
I agree with Justin.  Looks like remnants of the paper filter media you installed.  That filter may be causing more harm than good.
 just saw your avatar.. lol... more lemon pledge... lmao.. love that character.. funny dude
When I started working for Pontiac in 1969 we put several sealer pellets (called 'um dog turds) in every new vehicle just to stop the occasional coolant weeping from some of the hose connections.   I don't know if they still do or not, but that looks like what it is.
I agree there's a few things that people do that can actually hurt the performance, I was just running a test to see if I would actually find anything and I did I'm just sharing my results I'm not trying to reinvent the wheel here I promise haha. I have just noticed on many high mileage trucks the coolant gets dingy and dirty that's a fact, I was just trying to figure why since its a closed circuit. I'm not trying to create the frenzy on hey everyone go buy this filter your truck will run 10x better I just thought the amount of stuff I found was kinda crazy? Obviously these trucks run many miles with no issues that's why I said it isn't critical because these trucks don't run any kind of tight tolerance cooler that this gunk could really get stuck in.
I don't think this will adversely affect the cooling efficiency of the system over the lifetime but I do believe it could at least help, marginally maybe, but at least this stuff isn't running around in my system anymore?
With that being said I think its always a good thing to improve on any aspect of the vehicle I mean just think if back when the ls1 came out if no one tried to improve we wouldn't have the insane LSx and now LT markets
I didn't think it was the filter at all, when I pulled it out it was 100% intact. I also think if it was filter particles they would be the same stained dex cool color and similar materials creating lumps of stuff the same color in the filter pleats and this stuff is a different consistency and color. While it is a "fuel" filter it still has the same basic construction/media as any other oil or coolant filter and I would say oil in most cases easily gets as hot as coolant and under much more pressure and they aren't coming apart? I truly believe it's just sands/dust/etc from manufacturing the filter has a rating of 20 microns so I'm sure plenty of microns get left in from the factory these trucks are mass produced I doubt they get detailed to the micron like a race engine.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
