Largest tire with stock 20 inch wheels
Front driver
Front passenger
The front passenger is the only one I’ve been able to get it to run on while I’m a right turn. Doesn’t even need to be a full lock. If I pull the liner back I think I’m good to go.
  • Replies 88
Front driver
Front passenger
Sorry if I missed it, what year is your truck?
1 minute ago, TXGREEK said:
Sorry if I missed it, what here is your truck?
2018 GMC 1500 Crew Cab Short Bed Max Tow
Yes, I’ve heard of it, the 16-18’s all have stamped steel UCA’s, if you leveled it then put the tires on it would’ve been completely different story. Leveling these year models apparently changes the geometry of the UCA’s so that cause tire rub on the UCA’s. I know this cause it happened to me. That’s a very tight fit which I’d highly recommend keeping and eye out not hitting any hard dips especially while tire is turned and being that it’s plain mathematical, try turning while backing up on a full lock, does it then rub?
Here’s how a safe distance should look like for bigger sized tires in case hard dip happens without causing fender damage.
Btw, if you’re happy with it and (looks good) you’re getting no rubbing DO NOT LEVEL! You’ll then get the notorious and dreaded RUB.
As of right now I'm happy.  I don't see where it could rub on the UCA though.
It’s guaranteed to rub as soon as you do a level. Level will change the CV angle as well, bringing the UCA’s closer to tire, hence the notorious rub. Looks good as is, just keep an eye out for hard dips. Be safe
Thanks for the info
I take back what I said.  I just got underneath the truck so I could ziptie the fender liners back.  I got that taken care of but I noticed that my tires are slightly rubbing on the control arms at full lock.  GM really doesn't want people to modify these trucks at all do they?
GM stamped steel UCA’s was a cost decision. Spacers won’t help you either cause it’ll cause your tire to tear up the corner. Level will make it worse then you’ll need new wheels or spacers and then the best thing to do give tires back and get one size down
I’ll just try to not turn full lock often lol
Front level Bilstein 5100’s adjustable ride height shocks (with alignment) and spacers should fix it. Cheapest route! I wouldn’t recommend leaving it as is, damage sure to happen with additional costs.
http://www.motorsport-tech.com/4DCGI/switchtruckmodel
If you do go with spacers make sure it’s milled out for your hub rings to have a nice snug fit and Torque tighten the studs every rotation.
I'm not going to put spacers on quite yet.  I want to try and correct it in other ways.
My 18 Z71 4x4 CrewCab, added larger 275/60/20 tires, got rub. Did the level got much more rub. Bought different +1 offset wheels and 285/60/20 tires with zero rub after I zip tied. I could’ve added spacers saving at least 1K but I wanted a more aggressive sportier look. I’m letting you know what happened to mine so you’ll know what you’re getting yourself into. Good luck and God Bless
Much appreciated.  I love the wheels that I have.  I don't want to get rid of them.  I would rather spend money on control arms to fix the issue if I can.
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
