What and where are you guys using to mount your phone in the cab? Looking for some pictures of setups! Include links to mounts if you can also!
I used to use a magnet mount that used the CD player. Found it blocked the hvac controls though. Switched to a pop socket vent mount. Its ok. Jiggles more than I like.
Edited by Roscopcoletrain
I had one of these:
https://smile.amazon.com/gp/product/B01BZC262Q/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
*EDIT* Looks like there's a newer model getting good reviews for durability over the old one:
https://smile.amazon.com/iOttie-Dashboard-Windshield-Samsung-Smartphone/dp/B076B27WP6/ref=dp_ob_title_wld?dpID=51EXcNKQgoL&preST=_SY300_QL70_&dpSrc=detail
Nice mount but the bouncing of the truck eventually wore the joints out and the suction cup has a gooey material on it to make it stick better.  When you remove it, it leaves some of that gooey stuff behind and it's a real pain to get it off of the windshield.  If you go the route of something like this, DO NOT put it on your dash, it discolors it permanently.
Edited by Darmichar
I had one of these:
I’ve got a very similar one but mine charges wirelessly. I have it hard wired to the truck so I just place my phone in and it charges. I’ll work on getting pics later.
Our dashs are really high up, I dont like the idea of the sticky stuff on the dash? I use my phone alot for just the waze app so I can see traffic..
The one I posted above I had mounted at the top of the windshield so my phone was in landscape right next to the rear view mirror.  It was actually a very nice mount but the roads around her wore it out over the year and a half I had it.
I've been using this simple magnet mount for a few weeks now.
Magnetic Car Phone Mount, APPS2Car Universal Stick On Rectangle Flat Dashboard Magnetic Car Mount Holder for Cell Phones and Mini Tablets https://www.amazon.com/dp/B077GSPW9N/ref=cm_sw_r_other_taa_1UQGBb6QE5FGA
Strong magnet and extremely low profile. The radio bezel is tilted slightly towards the driver which is a perfect viewing angle for the phone.
And yes, thats a blackberry!! (Don't be jealous)
9a5f654d8398b6d78f63f1daab457910.jpge3deb1183f81b07a9ef767e2559e6a7c.jpgf0f66f24e44ca7c0f1ddc5a60456418c.jpg
Sent from my SM-T700 using Tapatalk
  • Haha 1
I have Pro-Clip's in both my car and truck.  On the truck it's slightly over the passenger vent but it doesn't block much air or anything.
I like the magnet mounts in most of my cars, but every place in this truck that can work seems to block a vent...not an option in Texas heat.
Is have the floor console that has built in cell phone holder up by the power ports. Then I run a charge cable from inside the console to phone. That way I don't have to much excess cable laying down in tray and keeps all the ports up front open and clean. The if I need to see the phones screen out maps I use andriod auto and project to the radio screen.
Sent from my Pixel XL using Tapatalk
Does anyone have a picture of the Proclip prior to installation?  I have no problem paying for a good mount, I just want to see what it is.
You can see some pics on their website.    You have a choice of mounts which you slip into the gaps in the trim and then depending on your phone size you choose a device holder.   In my case I have the Angled Dash Mount (for the right side).    It comes with 3m double sided tape, but it holds fine without it and  I've never felt the need to actually use it in any of my cars going 10+ years back.
https://www.proclipusa.com/vehicle/dashboard-mounts/9734-chevrolet-silverado-1500-series/2018
My last truck had a phone holder that slipped into the CD slot. A year later and it’s still sitting in the glove compartment of the new truck.
With CarPlay in the new truck, I rarely look at the phone anymore. I plug it in and usually just throw it in the storage compartment.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
