On 8/26/2018 at 8:17 PM, Black02Silverado said:
The Resonance Free Pipe (RFP) takes the place of a traditional resonator with much less weight and bulk. Some vehicle applications however still use resonators. An RFP works by venting a small amount of gas through the mesh in the pipe to break up standing waves which cause resonance in longer pipe sections. One tuning valve is used on the 5.3L L84 and two tuning valves are used on the 6.2L L87.
Interesting, thanks for posting.  Exhaust tuning my '17 truck has been one of my biggest frustrations.  By tuning valve do you mean flapper valve, like the one that is currently in use? That thing is the bane of my existence.
They are calling the mesh screen a tuning valve.
I don’t want it loud like a different muffler loud I just want a little more sound I’m gonna go cut them today
It all depends on the muffler you buy. Not all muffler swaps are loud. Look at a Borla ProXS if they're still available.
  • 5 weeks later...
I put a flowmaster 40 series on and it sounds great
Sent from my Pixel 2 XL using Tapatalk
on my 14 I just had them cut off and be done with them, better sound , will probably do the same on the 19
that sounds like a terrible idea
if you just want a little more sound you should get a CAI instead
No.  Works for drone/resonance elimination.  Change the muffler out.  That will get you more sound.
I put a flow master on my 2017 and the value behind the muffler I opened it all the way, sound great. Have not had no issues.
Yeah I was thinking about the flowmaster 44 for my 19.  Guy on you tube just put one in along with changing to 3” pipe from muffler back and it sounds great!
Has anyone had luck closing off the mesh resonators? I just bought a new Silverado Friday and had a Flowmaster Super 40 installed yesterday. I looked under the truck and didn’t see resonators so I thought it would give me the sound I wanted but it’s sooo quiet. It has a great tone but even a cold start is quiet and you can still hear that stock vacuum cleaner sound when you rev it, along with a muffled good tone. I wanted mild but this still feels like what stock should sound like.
A simple hack, not the greatest looking but the cheapest would be to cut open a beer can or soda can and cover the mesh screens up with that and two hose clamps.  That should block off the screens enough to give you and idea of what  the sound change would be I would think.
I’ve thought about trying some temporary hack like that. I’m curious if there is anything inside the pipe as well though. If there is some kind of obstruction within the piping, I’d just get the pipes replaced. But if it’s just hollow pipes with mesh cutouts, I’ll seal them up.
I think ill I’ll deconsruct a wire clothing hanger and stick it through the tailpipe and see if I hit anything lol
Edited by Jstnelson
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
