2 hours ago, jamez74 said:
Ordered it through my dealer. Install is easy, probably 15 minutes,  if you don’t mind wrecking the old emblems.
You don’t have the part number by any chance do you? I’ve had some horrible luck with dealers around me.
19 minutes ago, romclean1 said:
Looks great..now I’m going to have to get the chevy version, was it pretty much plug n play ?
Thanks! Plug and play, it just plugs into the headlight plug.
Not offhand. I am at work for a few more hours. There is a black version also, I will attach a pic that has the part #. I wanted the black one but they want way to much for them up here in Canada.
Edited by jamez74
Had the fog lights and the cover installed a while ago.  Took a long time for the dealer to get the fog lights to work.  The seat cover I put on myself. The pic is bad but I like them.
Finally got these installed... am I the only one who is super pissed the “Silverado” is in the front on one side and back at the other??...
On ‎1‎/‎16‎/‎2020 at 10:43 PM, Ryguy said:
Here are my mods so far:
35x12.5 18 Atturo trail blade MT
Black wheel locks/wheel studs
1.25 “ spacers all around
trimmed mud flaps and removed bracket
Rigid SAE LED Fog lights
Sea Light LED headlights high & low
Black Rhino side steps
removed all the badges except the grill Z71
white inlay front grill over Chevy
custom black leather interior with white stitching
Which Rhino steps are those???! I need those. Look high and tight with good ground clearance.
Thanks
I like them on my truck too...had them remove the high country ones and install these instead...but the paint is starting to come off one of them already. Time to go back to the dealer and warranty it I guess.  With less than 4K miles, It doesn’t give me much confidence in the paint.
  • Sad 1
I knew I should have gotten the Westin HDXs... I was torn between the two.  Hopefully I get lucky...
I'll take them off your hands if chevy doesnt want to play
What brand are the seat covers? Shopping for a reasonable priced set that provide good protection.
They are Ruff Tuff very durable and nice fit/ finish.  A little pricey but I am very happy with them.  Customer service was just ok but they are responsive at least. I would definitely purchase again.  Your finger tips will get a work out they are an extremely tight fit.
I expect they’ll just swap them out, I’m going to ask that instead they just run them through the body shop and rhino or bed liner coat them.
Thanks
https://realtruck.com/p/go-rhino-rb20-running-boards/grh-69409980pc/?cparam=b305ac536fe51440f96200af6c766947&gclid=EAIaIQobChMI9-H3h-vN5wIVl7fsCh37hAZnEAQYASABEgLdi_D_BwE
The mounting brackets do hang a bit lower then I would’ve liked, eventually I’m just gonna make some new brackets that sit flat
That is how they should have came for almost a grand and being labeled as "sport"
    Chris80s
    Chris80s
  • Who's Online   6 Members, 0 Anonymous, 929 Guests (See full list)
