On 7/13/2020 at 5:40 PM, HokieTodd said:
RC 3.5” lift
285/55r22 Nitto Ridge Grappler
Flowmaster Super 44
Looks great!
Thinking about doing the same - except I’d be replacing a LoMax, but basically same as Bakflip. Any extra insight or tips? What was your motivation?
The main thing is I want to run crossbars and the bakflip wasn’t a great option for that, I got some bars that worked with it but it wasn’t exactly what I wanted. I also had some trouble at first and the cover rubbed some paint off my cab from being in the up position. I got new rubber strips for it and it’s fine now, but I really liked the sliding cover, no drill design of the retrax and the rail system for adding bars. My only gripe is the drainage tubes that came with it don’t work for the holes in the bed near the cab. There are holes in the floor of the cab but the tube is too large, I have to widen the holes when I get a chance. Overall, both are great covers depending on your needs!
Thank you!
Added 2.5" front level kit and a 2" rear block lift. Love the new stance! Made plenty room for some 33's now.
  • Like 4
On 7/13/2020 at 5:21 AM, Flatblack83 said:
35 12.50 20 bfg km3s, removed the mud flap brackets, pulled the liner back with a zip tie and no rub.   Also tinted corner lights and mirror lights.
Any other mod for this set up? Spacers, level. No type of rub at all? Thanks, looks great.
Up front, Icon coilovers set to 3 inch, rough country uca's. Removed the mud flap brackets and pulled the liner back.  On the rear just 1.5 blocks and bilsteins.  Now these are trailboss replica wheels with a +15 offset. So that helps keep the tire off the uca's.
How's the ride quality with he ICON coilers? I am looking at ordering their kit, but can't seem to find much info on the GM/Chevy  installs. I found a video of a guy putting them on his ram, road bumps and trains tracks appeared to be absorbed by coilers. I don't do much off roading with my AT4, so the I won't be getting the reservoirs.
They are firmer than the rest, fox or king will ride smoother. Its firm but handles real well. I don't have the reservoirs either, mines just the stage 1.  The less preload the smoother tho, thats why mines at 3 inch and not 3.5.
Installation is pretty easy, not much too it. Make sure u do some sort of control arms tho.
Edited by Flatblack83
Added 6 3/4” led grill lights. 4 up top and 2 in the tow hook recesses. Went with red to match the red trim on my AT4. Ran a separate harness and switch to avoid messing with any factory electrical. I don’t have any night pics yet.
Look's Good - might check local laws ??  Minn. & Wis. - ONLY white or Ambler .
2" SST
285/75/18 Ridge Grapplers on stock 18" AT4 wheels
Surprised that i have zero rubbing anywhere. Tire is close to the control arm but has enough clearance.
Started the install on my radar detector.
Need to order the upfitter parts so i can have it switched and all wires hidden.
Edited by BetaX
Looks good. Where did you get the lights?
Sent from my Pixel 2 XL using Tapatalk
Not only Mn and Wi. Most likely that all states will follow USDOT, which says, uh-uh.
Installed Tyger Armor steps.... These things are super rugged. Happy with the outcome. cca1b1f6c9f035e348a39fca8931f1a2.jpg
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,951 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
