1 hour ago, mdf21 said:
Got the 3.5” RC lift kit installed on my ‘21 Denali. Should help with the ground clearance hitting the woods and the ride is just like factory
Nice! If I may ask, what size tires are those? Any rubbing?
Thanks. 275/60R20 same as factory.   No rubbing at all
Thanks for the quick reply. Are you perfectly level with the RC kit? Or do you have a little rake?
It’s pretty close to level with just a tiny bit higher in the back. Here are my before/after measurements to the wheel well:
Before
Front left 36.5     Front right 36 5/8
Back left 39         Back right 38.5
After
Front left 39.25     Front right 39.25
Back left 40.5         Back right 40.5
Before
After
Thanks. Did you adjust your headlights?
I haven’t messed with them yet but two trips in the dark after the install and I haven’t been flashed by oncoming traffic yet so it’s either not too bad or the shop adjusted them already.  I’m gonna keep an eye on it and adjust if necessary
Added a light kit to the multi pro tailgate. Got this one on Amazon vs the GM kit at half the price and larger LED modules
  • Like 6
Last week I was finally able to finish the wireless charging addition to my truck.  Had to switch the wire harness so that I got the factory navigation working in my truck again.  Figured I'd take the time to get the project done right and added the air duct tube that goes to the wireless charging pad.  That was a PITA due to having the Bose system.  Also had to pull a blend door actuator to get the tube installed by the lower glove box.  Everything is working as it should now.
Today I finished my custom wiring of the Rough Country grill lights to the GM Upfitter auxiliary switches.  I really wish GM had pre-wired the auxiliary switches into the truck like Ford did for the Raptor.  Connecting to blunt cut wires under the hood instead of trying to shove everything through a tiny hole in the firewall would make everything so much easier.
I got rid of it!
And FINALLY got its replacement. The 2021 I ordered (same specs) has been sitting in an overflow lot in Roanoke IN since 3/17/21 so I ordered a 2022 with the exact same specs and look what came in first LOL This is our new development vehicle a 2022 Denali Ultimate CarbonPro LM2; also my first diesel and so far I'm LOVING IT. Definitely a different driving experience over gas but so far even with like 100 miles on it the fuel economy is insane as is the torque.
At any rate it stayed stock for about 50 miles (this likely wont surprise any of you) first mods were WAMS Custom BCM programming (fogs with high beams, windows up from fob, remote start run time increase etc the usual stuff), WAMS Custom High Country Cluster to replace the Denali cluster with GMC graphics (lets be honest it looks better than the Denali unit lol), auto cooled and heated seats/wheel and an AutoStop Eliminator. Next up I'll be swapping in one of our wireless CarPlay kits to get HD radio back then after that maybe screw around with the rear heated seats LOL
Detailed the inside today, just needs a wash and wheel spray.
Putting wheel skinz on my 1500 today.   I've had them before on other trucks, but these are by far the best fitting I've had.  On past ones I've seen a slight bit of the rim, but with these you cannot see any of the rim underneath.
What ya guys think?   I have to get black center caps.   I can't decide if I should get chrome bow ties or all black.  My lugs are steal / chrome.
only had the truck for a few days and already put wheels n tires on it...
RWD Silverado.
Vision Turbines 17 x 8.5 +18, Cooper ATP II 265/70/17
I think they def compliment the color of the truck...
Nice!
My first thought is all black center caps, but If your keeping the chrome lug nuts, I'd go with chrome bowtie.
Do you have a link for those wheel skinz?
1 hour ago, bdallas said:
Nice!
Thank you!!    It's much easier and better looking than dipping them.  Plus they don't scuff the rims.
Here is the link:
https://www.ebay.com/itm/Set-of-4-20-Wheel-Skins-for-2018-2020-Chevy-Silverado-Gloss-Black-/265069670261?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=711-127632-2357-0
Looks great!  I'm partial to all black and even got the lug nuts from GM Accessories to get rid of the chrome.
19 hours ago, GTPprix said:
I got rid of it!
Congrats!  Even after owning my truck almost 18 months I have a love/hate relationship with the engine.  I love the power of the 6.2, but hate the fuel expense.  $5/gallon for 91 (closest to 93 you can get in California).  Diesel is cheaper that regular.  However, I know that no matter what I had gone with I would've not been 100% happy.  I do wonder what it drives like though.  Never got a chance to try out the diesel (nor any of the engines) before buying.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
