On 3/12/2019 at 7:46 PM, Ravenkeeper said:
Looking at doing the "Sport Bar" on my Silverado.  What tonneau cover did you get?  Also, can you send me pictures of the top and under (between the pipes)?
https://accessories.gmc.com/product/2018/GMC/Sierra 1500/standard-box-premier-roll-up-tonneau-cover-by-advantage®---associated-accessories-19355363?categoryId=98027
I got this tonneau cover installed on my truck when I bought it from the dealer.  It fits well, but when rolling it up it gets a little tough where the back of the sport bar meets the bed rails.  Almost have to tilt it a bit to get it to go past.  Other than that, it works great.
Can't take any pics right now, truck is sleeping at home and we got some snow today.  I'll try this weekend.
Would it be possible to take this switch and reverse the fog light and orl buttons to have the orl button to be instant on/off and the fog lights be on/off hold for 3 seconds?  I'm guessing you would have to switch the wires from the switch at the BCM?
Edited by bndawgs
On 9/15/2018 at 2:52 PM, TinkeringFox said:
Have you seen the Michael J Fox Edition Sierra/Silverado rolling down the road? Looks like the Toyota from Back to the Future. Anyway there is a really cool headlight switch with the option for Off-Road lights. Apparently with a long push of the button the BCM will latch the signal and provide a constant positive signal for triggering a relay. It will also illuminate the icon on the switch as well as send a signal to the cluster illuminating an amber light icon next to the fog light icon or “ORL” in amber.
I successfully installed this in my wife’s ‘16 2500 Denali yesterday but from what I’ve read it’s the same for 1/2 tons, HDs, and Colorado/Canyon.
The BCM already has Programing for this from the factory but I’m not sure when (how early) it was started. I have a ‘15 3500 that I’ll try soon as well as a friend’s ‘17 2500 to do soon.
If the Programing hasn’t been done in my ‘15 I’ll still be able to get the switch to illuminate as well as latch a signal for positive or negative relay signaling using a latching relay.
There are several variants of this switch. Some have blue background for ‘17+Up model years and red for ‘16+earlier. Additionally some have the ORL switch without Fogs, and some have no surround backlighting.
Here is the video from yesterday’s install.....
......More videos to come for other uses like work lights, incorporating into the X50A, rear facing lights, non programmed trucks.....
Pgamboa has been very helpful in discussion about this as well as providing schematic-Thank You!
I've run through a few pages on this thread,  and watched the video a few times. I have a few questions if you don't mind. First simply being what is the part information for the Delphi (hopefully the correct name) crimp / ends, I have the number for the JST from the video being SAITS-A03T-M064, is this correct? Are they the same for the Delphi? Also, is there a link or part number to the Delphi crimp tool, or will any crimp tool be sufficient? Any and all help is greatly appreciated.
I jumped the gun and purchased the Red surround switch and later verified mine are Blue (2016 Silverado 1500 LT). I wanted to attach an image of my existing switch as it doesn't resemble most on here.
I believe I answered my question about the Delphi crimps.
Is the second image the correct tool , used in the video?
The pic of the switch you posted isnt the offroad switch. Thats just the headlight with fog light switch. But i guess you could do the same thing though. Does your truck have factory fog lights?
That crimp tool will work, you might need to finesse the edges of the crimp to make them conform to the cavity but they’ll get it done. Bummer about the color but I’m sure you’ll find a buyer. Also I’m pretty sure @pgamboa can send you a harness cheaper and faster than buying the tool, wire, tape and terminals...etc Also I haven’t seen a Silverado or Sierra with anything but JST connectors, the written instructions are for a Canyon/Colorado.
The picture I posted was simply my existing switch, I believed it to be slightly different than others existing switches on this thread, prior to replacement. I do have fogs and did purchase the switch from TinkeringFox's video.
I appreciate the response, I went ahead and snagged a set , doesn't hurt to own a pair for the future. They are eerily similar to my MC4 crimp tool, which is for photovoltaic installation connectors , so I may already own a tool for the project,  duplicates never hurt. I found the exact part number for the crimps on Amazon (25 pieces) ,  no image though, hopefully they are the correct female ends.
I think there is only a couple diff switches. Might be wrong though.
Headlights
Auto headlights
Headlights and fogs
Headlights and fogs and off road lights
And of course red and blue depending on chevy and gmc and year of gmc.
Edited by RACERX7775
51 minutes ago, TinkeringFox said:
Nice find! Let us know...
Once I've accumulated all the components,  I think I'm going to tackle the OEM switch with BCM and aftermarket relay integration wiring first. Then get the lighting feed completely in place and leave fuse out. Then install my fixtures. Hopefully all goes well. I greatly appreciate all the input and knowledge here. I attached a few images on the trucks current state. Doesn't appear to have much done, but it's been a busy month. It was a 2016 LT Z71 crew cab. Already replaced headlights and taillights with LTZ, Weathertech Floormats,  Weathertech mud flaps, removed silverado rear and side emblems,  replaced side with Z71 emblems, replaced both bowties with black, replaced oversized antenna with 4", K&N intake filter, new black hitch pin, repainted hitch , had the hood, fenders, grille,  front bumper, and tailgate repainted,  Z71 license plate frame, Go Rhino sport bar, every exterior lamp replaced with LED.
I have Weathertech window visors / deflectors in transit, as well as (5) Rigid Industries Q Series LED fixtures for the sport bar [ (2) diffused , (3) flood].
I know I've names some dinky items, but it's all added up, so I thought I'd mention them. Hopefully I'll have an update on the sport lights shortly. Thank you
Looking good. Check out this behind the grille lightbar mount.....
http://www.socalsupertrucks.com/2014-2015-silverado-sierra-led-light-behind-grille-mount.aspx#.XKQEQhpMGfB
I installed one in my ‘17 2500 with a Rough Country 30” curved bar.....
https://www.roughcountry.com/30-inch-led-light-bar-70930blkdrl.html?rrec=true
I wired it in so the high beams activate it when I have the ORL switch “on”.
Another brilliant idea, Definitely looking into wiring some additional lights, and the high beam option sounds like a great idea as they should never be on during traffic anyway, unless someone forgets to turn their high beams off headed towards me, which they are in for a surprise lol. I also plan to hang two rear facing LED ORLs for additional reverse lighting when trail driving / out in the dark. Pondering on how I desire to have those controlled , as I don't want them to be on the reverse circuit and turn on in my local grocers parking lot , and blind the masses. Thinking of using the spare locations near the traction control switch. Anyone know where to purchase those Aux switches, proper name / terminology for those switches?
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
