Just finished the leveling kit on mine.        1 1/2 Motofab from eBay for $21. Went on in an hour and sits about perfectly level now
What are your measurements now: floor to center of fender? Front and rear? Whenever you have a chance if you could share that info that would be awesome. Preferably after alignment and suspension settlement lol [emoji4]
Did you install yourself? If yes how did you tackle it? Loosening tire rod end...upper and lower ball joints...and sway bar end links. Or did you follow the “easy way” you tube video where they only lift the truck and loosen the two lower strut bolts...remove and sneak in the spacer then install bolts.
1 hour ago, asalinasz39 said:
What are your measurements now: floor to center of fender? Front and rear? Whenever you have a chance if you could share that info that would be awesome. Preferably after alignment and suspension settlement lol emoji4.png
I drove it about 40 miles this morning. Haven't done alignment yet. You would never even know I did anything from the driver's seat. Rides the same. Handles the same. Steering wheel is straight and it holds it's line with my hand off the wheel. In spite if that I'm still going to get it aligned as I assume it needs it and I don't want to wear out the outside edge of the tires.
The height as of right now is 41.5 to the front wheel well and 40.75 to the rear. According to measurement I'm a bit too high in the front but it looks really nice to me!?
Did it my self. I've done probobly 5 of these over the years. So simple. Hour to hour and a half tops. It helps to have a helper. For me that was my 16 year old daughter.  Trying to get the spacer in and everything lined up to slide the bolt through takes a third hand sometime  Took upper tie rod apart. Loosened sway bar. That's it!
Edited by Ben Berkenpas
do you have a pic of your cv angles after the spacer install?
truck is sitting on a level surface and tires are straight in this picture. The angles really look fine to me!
It looked more on the level  side before the lift. IMO, I would've left it as it was. Now the front end obviously looks higher.
If you stick a level on the top of the box side, it's still too low in the front.
I've always lifted trucks based on level box sides not measurement off ground to wheel openings.  Old square body Chevy's in the 80's, the front wheel well was about 2 or 3 inches higher to the front wheel wells so you had to base level on the box.
I think it turned out great and I wouldn't have wanted to go any less. Just my opinion!
Looks good to me, thanks
3 minutes ago, JR09country said:
Cleaned up the front fender. Debating on removing the trail boss sticker emoji848.pnga96b3c3fd5f05aec7375215566123c3b.jpga61129090799edbac95878d0b1eeb963.jpg
Sent from my ONEPLUS A6013 using Tapatalk
I definitely like removing the fender badges/GM has gotten carried away here/way too big/out of place.
The rear I don't mind as much whether it's trail boss or 4x4.
I took my Trailboss sticker off the first day I had it. One if those things that 10 years from now we will look back and say "remember when Chevy made a "Trailboss!?"
“Trail Boss” is tame compared to some of the packages throughout the 70s and 80s. The “Gentleman Jim” has to be the worst...
  • Haha 1
That is both AWESOME and Embarrassing at the same time!
The height as of right now is 41.5 to the front wheel well and 40.75 to the rear. According to measurement I'm a bit too high in the front but it looks really nice to me![emoji23]
Thanks great info brother! My AT4 has a 2.5” rake from factory...I keep measuring and keep getting 38.25 front and 40.75” rear.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 960 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
