50 minutes ago, Joe98 said:
Guys.... you’re killing me !!!   Please stop posting pics of these gorgeous rigs... I’m torn on a new 19’ Sierra AT4 in white with 20” wheels,  or a left over 2018 Denali in black with 6.2, its not an ultimate and has regular chrome steps.   Any advice or suggestions would be greatly appreciated.
Some beautiful trucks on here folks ...
Joe
Joe
For me, it would come down to the price difference. I actually like the 18s interior over the 19s....Assuming both are 6.2
Edited by 04SierraSLT
On ‎2019‎-‎06‎-‎09 at 11:31 PM, RUSSH said:
I'm glad I decided to get black wheels for MY truck and you guys got the wheels you wanted for your trucks ?
Even had them on my  2017
Well said... to each his own....I have chrome, the next guy has black.The bottom line they are makin' the payments!
  • Like 3
Pulled a skid steer today. about 10k lbs. Truck squatted about 3.5 inches and I was almost all the way at the end of the trailer. I think it is time for air bags
1 hour ago, HapaTrailBoss said:
Chocolate Falls this past February
IMG_3922.MOV
Looks like the surface of Mars. Satin Steel really pops in the sunlight :thumbs:
What part of the country?
Or a 2500 HD !   Wow that is a load for a half ton.
Do you have the 5.3 or 6.2 ?
Joe
I briefly had an '18 Denali with ultimate pkg, traded in on my '19 AT4.  With the 2018, I never felt like I had a "new" truck just for the simple things like no keyless start, the wireless charging tray was not big enough for "plus" sized phones, it didn't have the button unlocks on the door handles, etc.   I had to get my drivers seat cover replaced in the denali so I had a loaner '19 AT4 for a day and got to experience the differences in the newer models.   I personally thought the retracting side steps were annoying, and I never could see the value in the expensive denali suspension.
The Bose system is hands down better in the '19 AT4, the software look/controls in the console display look better and are easier to use.   Love the tailgate on the '19, and the 6.2/10 spd tranny is awesome.    I recently made a cross country towing trip with it - no problems.
  • Thanks 1
5.3. Truck is rated for 9600 and I had 9500 +/- 200lbs
I usually stay under 55mph and its only 20 miles round trip once a week. Thought of buying 2500 but they are 10k more for similar specs 6.0 gas
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
