18 minutes ago, ct_corey said:
What are you wheel and tire specs? I am thinking about order the same wheels but wasn't sure what offset and tire size. did you need a spacer to clear the front calipers?
I have the stock 20" Trailboss wheels that came on the truck. Tires are also stock (Bridgestone Dueler 265/60/20).
On ‎2‎/‎28‎/‎2019 at 10:08 PM, jj_marshy said:
Well, here is a before and after. It does look more leveled to me but I feel like it’s still off and not as leveled as yours. What do you think? Is it just me? FC23CF49-0F12-4D7A-AAED-E11D53D6379F.thumb.jpeg.02f28321859e06698198b7051b8daffe.jpeg
sorry I meant to quote this truck
I don't get why get thinks that they need all these parts to gain 2". Seems like a huge waste. Anything with a Z71 on it should have that(offroad...).
I would think that a name like trail boss would mean it was trail capable but I don't see that as the case. Sure they will go down a trail but no one buys a new GM because of the trail capability.
Sad really.
Sent via Morse code
Sad really.
Sent via Morse code
Can't tell if your trying to be a comedian here or if your serious?
It wasn't really very funny and it didn't really make any sense!
If you don't care about this topic, don't follow along. It's pretty simple!
Sad really.
Sent via Morse code
I bought mine for that exact purpose , to go fishing and hunting down trails ... so yeah I DO buy a new GM for its capabilities and because i F*&^% love the look and also because I CAN !
Plus we do want we want with our trucks ... why do you care ?
On ‎10‎/‎22‎/‎2018 at 10:47 AM, L86 All Terrain said:
Leveling the front only is great if you're just a looks guy, but a bad decision if you tow or carry loads with your truck. Put the rear block in if you use your truck as a truck.
Trailboss at my dealer looks like you could stuff a 35" in there, turning may be another story. If 35" tires are on your list of needs, you need to save up enough for a true 4" suspension lift as said before a 2" lift on top of a 2" lift is not the proper approach without re-designing your suspension and drive-line geometry. By the time you buy the proper CA's/BJ's, drop brackets, axles etc. you will be more $ into it than a 4" suspension lift. No cutting with most 4" lifts as well so there is that bonus over a 6" lift and they are usually a lot cheaper.
 Why is that? I know plenty of people on here who tow with 2" levels, myself included. Granted, I personally rarely ever stuff really heavy things in my bed and my 17' boat only weighs about 2,300 lbs including the trailer.
Same here , i towed my TT that weights 8000lbs wet and had a full box on a 2" Levek Kit on my 16 Sierra and it towed just fine ... never had any issues before i traded in for my TB
So do I, up to 8,000lbs with my little levelled half ton. The reason I say that is by only putting the front kit in, you are taking the rake out of the truck, so you will be squatted and look overloaded with even the smallest loads. The rake is there with the rear blocks so the truck rides level with a payload (what they were designed for). Without the rear blocks, your front end is pointed at the sky, your rear end is sacked, and everyone high beams you at night. I say do the front kit only if your a looks guy that treats the truck more of a sports car than a truck, do the rear blocks also if you actually have to do truck stuff.
I am towing 2% of the time. I want the truck to look level the 98% of the time that I'm not!
  • Confused 1
I have 2” in block in the rear..
On 2/21/2019 at 4:11 PM, Ben Berkenpas said:
So I have a 2019 trail boss lt crewcab coming with stock black 18's on 275/65/18's I believe. I plan on changing out wheels and tires but sticking with 18's. maybe a 33'' tire? anyways, when I click the link for the level kit and put my truck info in it says not compatible. did it say that for yours also?
Edited by jtl1985
Correct. It says it's not compatible but it works great. Supposed to be a level coming out specifically for the Trailboss soon from a couple different manufacturers. I don't know exactly what those will consist of or how much they will cost. I installed the  motofab kit 6 months ago and have had absolutely no problems as have many people on the forum. Time will tell if we end up with premature wear on the front end parts but as of now it is the only fix for the factory rake.
so I talked to a local truck accessory shop and they said there are multiple 2" leveling kits out. ready lift has one and I can get it installed for around 300. but its a 2". id prefer 1.5 by the way others make it sound. I do haul my ranger 620 boat in the summer and a 7x16 trailer with atv and ice fishing gear in the winter. I don't want my front to be pointed up to drastically. im debating what to do. I have not got my trail boss yet but will in the next few days. it is on a train right now.
so what does everyone run for tires with the leveling kit on a trail boss lt? I ordered the understrut kit and prefer to have a little bigger tire. keeping the 18's but do I go 33" or bigger without rubbing issues? I've always had to trim and I really don't want to this time, maybe just he mud flap if I have to.
295/70R18 should fit with no rubbing or trimming necessary. Its roughly a 34.3" x 12" depending on the brand of the tire.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
