1 hour ago, Trailboss91 said:
Calm down boss, 90% of the people on here are installing bigger tires for aesthetic purposes, not off-roading. They fill out the wheel wells better. Didn't realize we were upsetting a consummate professional off roader. Guess its a good thing its not your truck.
Amen!
On 6/12/2019 at 8:25 AM, JuicyJosh said:
Well that definitely puts it in perspective ?
Bigger tires and no tire noise ?
On ‎5‎/‎21‎/‎2019 at 7:56 PM, obfirefighter22 said:
My LTZ 6.2 with the 2 inch trailboss lift, and 2 inch level.  Have 22” Chevy RsT wheels, and toyo open country M/T
Question.  First off, love it!
35x12.5x22 tire?  Did they rub before leveling?
Old tires 275/65/18 DURATRAC 45.8 lbs
New tires 325/65/18  Ridge Grappler 74.2 lbs
Fitment is flushy BUT 1lb unsprung > 3-4lb sprung ? . I might  upgrade to lighter rotors down the road ?
MPG has dicreased from 22.2 to 17-18.5 ?
Edited by TrailDemon
On 6/7/2019 at 10:27 AM, Trailboss91 said:
295/70r18 Falken Wildpeak AT3W tires, 34.3” diameter with no trimming needed. No level as well.
Looks great!! Been going back and forth between this size and 275/70r18.. how is the drive with those weighing in at 68lbs a piece? Have any other pics?
Honestly the drive has been great. I do a lot of driving so I have already put 1500 miles on them. Ride smoother and quieter than the Duratracs, as for MPG’s only seen a .5 mile drop. Around town you will definitely notice it in stop and go traffic but on the highway the mpgs stay around 17ish. I will add more pics tomorrow.
Edited by Trailboss91
Ok thanks. Hoping they will fit my AT4.
Another picture from today. Im betting they will fit on the AT4, im putting the 1.5” motofab level this weekend.
Everyone stating the 1.5" Motofab on AT4, is this the part number CH-15LM-TB lower mount spacer?  It sure looks exactly like the CH-15LM they offer for a regular 4wd 2019, and makes me wonder what qualifies it for the AT4 when others aren't recommending the same level kit for the two vehicles.
I believe I am still leaning towards the Rough Country 1318.
Edited by thsoccer3
On 2/13/2019 at 2:55 PM, destrada127 said:
I was kidding with the more room. I think it's the same if not less but I'm going to try the "hair dryer trick" on the fender liners to see if that'll give me a little more forgiveness. First pic is the rear of the fender well. 2nd pic is frontfa6f850c2da23886403f22f82e2d1333.jpgc9ca685f9b7d80fd80c9b661b162ab88.jpg2fe0ad53a9ad338e32a109163e2cdbe5.jpg
I tried duratracs 35.1 x11.2 and I had maybe 1/4” to the liner. Not much room behind it either. If I cut the liner out in the spot I figure maybe 1/2” before I rub metal if I take it off-roading for hunting. Do you have any issues hitting bumps and dips if your in full lock?
Edited by jtl1985
Anyone running a 1/4” spacer have a part number for the AT4?
I am not very experienced in wheel spacers, but want to have the right ones handy in case the 295/60/20 rub on factory wheels or possibly install anyway just to improve stance.
Everything I read the AT4 front wheel opening is smaller than the TB... FYI
Yes this is true
Bora are the best quality spacers available and they will make any size you need. I had them make me a custom 8mm thick with 78.1 mm hub x 106 mm bore spacer to fit my Fuel Maverick wheels.
I recommend their Hub Centric/Wheel Centric Spacers for a perfect fit.
http://www.motorsport-tech.com/index.html
    daveishi
    daveishi
  • Who's Online   4 Members, 0 Anonymous, 1,072 Guests (See full list)
