On 9/8/2019 at 3:47 PM, OnTheReel said:
Sorry and welcome to the club. Unfortunately you’ll have to settle in for at least a couple weeks of BS with your truck.
Are these leaks only happening to LT, LTZ trims with the Sliding Rear windows,  or what about Crew Cab vs Double Cab, any difference there?
Keep something in mind.  I found a leak on my 2015 and it wasn't from the sliding window.  It was actually from the third brake light.  They idiotically use a foam gasket to seal the light when placed into the enclosure of the cab.  I found that the gasket wore out and that was causing water to drip down the headliner over the window and to the back seat.  I pulled their gasket off and replaced it with a better rubber gasket from Home Depot.  This may or may not help some of you, but it's info that I'm hoping will help someone.
Anyone that ha had the rear window replaced have the part number? I’ve got the dealer to agree to replace it but they are asking me which window it is because there are 3 windows, left, right and? I would think it’s one window?
When they replaced mine, per my paperwork, it was part 84569182. Description - Window 16.464 N
On a side note...your dealer doesn't know what window? Seriously? Doesn't exactly inspire confidence.
Edited by fish_guru
more info
My dealer had trouble ordering the window too. It was the first one they had ordered and something about the part numbers made it seem like it was three different pieces. Ultimately they got the right one ordered.
I agree but it was my salesman trying to help me vs. leaving me in the hands of the service department and he knows I can find out information that he doesn't understand. I buy many vehicles from the dealership yearly and my salesman gets me further than the service department does.
Yes, thats what he was saying, 3 windows.
Copy that.
Hope you get it squared away.
Spotted stained headliner on passenger side this week. Build date 11/9/2018.
Going to dealership next Monday. Requested window replacement- will let you all know how it goes.
Just so I know... where is the "hairline" crack generally found? Looks like a plastic part based on images uploaded to this TOPIC..
Window frame? Window track?
Edited by Kozzy
The slider window frame tract.
You probably aren’t going to be able to see them with the spoiler in place. Good luck on getting a new window. Hope you can, but as I understood it, GM isn’t gonna pay for one until after the “gooping“ attempt fails at least once.
  • Sad 1
If you are looking at the rear window from back seat it is above the headrest, more specifically above the end of the plastic tract the window rides in. I was only able to see it once the headliner was pulled down. You might be able to push up on the headliner as far as it will go, you might be able to see it. Mine was easy to find because I just followed the river of water dripping in.
Ok thanks. Did you finally get your window fully replaced? Any leak issues since? @ShamrockShooter
Also- does anyone have a build date as late as mine (11/9/18) that is experiencing this rear window water leak? When I called GM and explained situation and referenced bulletin #18-NA-383.. I was told my truck falls out of the affected date window (10/18).
    Afennell19
    Afennell19
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
