Ok thanks. Did you finally get your window fully replaced? Any leak issues since? [mention=160416]ShamrockShooter[/mention]
Also- does anyone have a build date as late as mine (11/9/18) that is experiencing this rear window water leak? When I called GM and explained situation and referenced bulletin #18-NA-383.. I was told my truck falls out of the affected date window (10/18).
Yes got window replaced but they damaged a bunch getting it out. The water could also be leaking in the holes that the rear spoiler bolts to the truck. It could Also be a bad seal around the window, both of which would be different than most of the leakers.
Sent from my Pixel 2 using Tapatalk
Any issues since the FULL WINDOW replacement?
Nope. The new window looked slightly different than the old one so GM must have switched suppliers or part number from the early build
2019 TB LT.  build date 2/19.  Rear window now leaking. Both sides upper corners.
Oh joy.   Can’t wait to have dealers techs greasy little d*ck beaters al over my new truck.   Boils my blood just thinking of it.
Hell I can’t even get an oil change without oil residue on my steering wheel and dirt smudges on my seat.
  • Sad 1
This is the first truck I have heard of built after 10/18 with a window leak. They were all suppose to be fixed after 10/18.
Wish that was the case.   I’ve been keeping an eye on it because of the rain we have been having.  And ,  yes she’s wet.   Not happy to bring this up but is what it is.
Edited by Radchad
May very well just be the spoiler with that late of a build. My window frame was cracked, but the dealer also said there was no seal around the spoiler retainer holes which may have leaked eventually too.
Hopefully it’s just that anyway. Once they started putting the goop on the window, I pretty much decided to trade on the refresh. I’m kinda over it, but it will always bug me a little and I know it’s going to leak again one day.
On 9/22/2019 at 1:34 PM, BluEyeItln said:
Keep something in mind.  I found a leak on my 2015 and it wasn't from the sliding window.  It was actually from the third brake light.  They idiotically use a foam gasket to seal the light when placed into the enclosure of the cab.  I found that the gasket wore out and that was causing water to drip down the headliner over the window and to the back seat.  I pulled their gasket off and replaced it with a better rubber gasket from Home Depot.  This may or may not help some of you, but it's info that I'm hoping will help someone.
Yes, my 2010 and one of my 2013s leaked the same way.   Third brake light seal.  Not a hard fix.  Pull the brake light put some sealant along to top and sides of the seal.
Well damn that sucks. At least your not the first so there should be plenty of info in this thread. If it is the upper rail glass guide under no circumstances should you let them seal it. If they won't put in a new window, just call your insurance and file a glass claim and have Safelite replace it.
30 minutes ago, UGADawgs said:
When posting the 10/18 date from GM, are they saying 10/18/2018 or 10/31/2018?
10/18/2018
So , since mine is built 2/19.  That means no window replacement or what ?  I’m assuming it’s all warranty.   I’m nervous to have anyone hacking my window out.  Wish I could just do it myself
I've been thinking about putting in a power rear window in mine.  The window itself isn't hard, the hooking up of the wiring and button for it, that is another story.
Mine has build date 11/9/2018 and is a leaker. Going to dealership tomorrow- going to push for full window replace.
Edited by Kozzy
17 minutes ago, Kozzy said:
Mine has build date 11/9/2018 and is a leaker. Going to dealership tomorrow.- going to push for full window replace.
Just because you have water inside doesn't necessarily mean it's the rear window leaking. In my case it was the 3rd brake light housing that needed resealed. It is going on 4 months since they resealed mine and still no more leaking.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
