1 hour ago, ShamrockShooter said:
I thinking this has to be a freeze thaw issue.
Bingo.  If the truck didn't leak for a while and then starts all of the sudden, it is being acted on by outside factors.  It's either sealed or it's not.
Let's take a poll to verify this theory...where are all these leaking trucks located geographically?
Edited by lapoolboy
Out of curiosity,
Since this issue seems to affect all build dates. Has anyone noticed if this is happening to both US and Mexico assembled trucks? Majority I've seen here seem to be the Ft Wayne builds.
Both of my trucks were 1Vin ft Wayne
Sent from my Pixel 4 using Tapatalk
Or the plastic frame of the rear slider cracked from hitting a pot hole or the truck flexing pulling in or out of my steep driveway
Both possibilities I suppose but they are still outside forces.  Do you notice any cracking?
I dunno. Mine was fine throughout all of last winter. Didn’t leak until August. Just completely out of the blue. Definitely wasn’t any freezing or major temperature swings going on.
If I were to hazard a guess, the truck just ain’t stiff enough. The roof area flexes over time and eventually breaks the seal and/or cracks the window channel.
Still can’t think of any explanation for why the issue is still happening though. The window was allegedly redesigned and suppliers changed. All I know is that the “first year of a new redesign” card is expired. 100% unacceptable that a thread created in November of 2018 is still claiming victims 13 months later, on the next model year!
Big time rain in so cal tonight. Well see how the new fix goes GM just did on my rear leak. I’m overseas , call the wife tomorrow to check k on my truck.  Cmon GM I hope you fixed it right.
7 hours ago, Tomtom87 said:
Out of curiosity,
Mine is a Mexican build and I’m in Easten NC.
Edited by JohnCasey
Ft Wayne build.
kentucky
leaked November 1 - still hadn’t had any freezes or temp changes.  And it is garage kept at night
That makes me think pulling in and out of my steep driveway every day which causes quite a bit of flex in the truck might be what broke the seal or plastic frame on my back window. Just the morning fog/dew on the truck today was enough to make it start dripping in so must be a big opening.
I'm inclined to think its a flexing issue with the body too.  We've had a similar issue with a Jet Vac truck of ours with the frame flexing and ripping the radiator apart. We crossed braced the radiator with 1/4" steel and haven't had an issue with that one since.  The dealership is swearing they are testing it the day after they fix it but it leaks after I drive it 10-15 miles and cross over two railroad tracks.
Well, just dropped my RST off for the leak. It was dripping when I dropped it off, so that was an easy explanation.
Largest volume Chevy dealer in America, and “dealer of the year” in 2018, and my service advisor said this is the first leaking window he has seen. Oh, boy. ??‍♂️
Just dropped mine off dealer said they have done 4 already
I'm 100% sure the dealer has done many of these repairs, so maybe my service advisor himself is new or had not seen one yet.
Largest volume Chevy dealer in America, and “dealer of the year” in 2018, and my service advisor said this is the first leaking window he has seen. Oh, boy. [emoji2359]
Please tell me you didn't take it to Bob Johnson Chevy in Rochester.
Ha, no. I'm in DFW. It's at Classic Chevrolet in Grapevine, TX.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
