32 minutes ago, Ethan Fernaays said:
Agreed would be just my luck that the replacement would begin leaking at 36001 miles
I wonder if a dealership would agree to actually do it
GM sure as hell wouldn’t pay for it, but I’m sure you could have Safelite or whoever do it. Still sounds like a lousy idea to me though.
31 minutes ago, Ethan Fernaays said:
Did u get a replacement window?  has your leak been resolved?
No, I got it sealed on December 26th. It started leaking again a week later. I took it back, but at that visit realized my dealer was clueless. So I made an appointment with another dealer 30 min away that was much more knowledgeable on the phone.
Still haven’t made it in to that appointment. Window was still leaking last week, but less. Then it rained the past few days hard, and it’s not leaking now. So weird.
9 hours ago, econometrics said:
Oddly, it’s rained like the flood here the past week off and on, and my previously-resealed-leaking-still-window didn’t leak. ??‍♂️???‍♂️
Yet, whenever I have a little morning dew on the top of the truck, I see a drip on the sliding frame corner. ?
That's when I noticed it the first time and after the caulk job, it would only drip after morning dew, not rainstorms or washes. Haven't noticed any drips since the new E4 window last week or so.
They are putting my headliner in as I type this.  I stopped by the dealership earlier when the pulled the glass.  I found two cracks through the frame that the service manager failed to notice.  They are putting my headliner in today and maybe the window this afternoon or the morning.  I'll pick it up on Monday at this point for a total of 79 days out of service if this is all the warranty work I have to get done.  They did tell me that I haven't been driving the loaner much. Apparently most of the people given loaners drive the heck out of them.  I did notice all of the steel hardware that holds the seat on the rear of the cab is rusting.  I will also say that their glass crew did a great job removing the window in one piece and did not put a single scratch anywhere that is exposed(there is one scratch through the paint exposing primer behind where the window seals).
Edited by JohnCasey
So after I found water in my cab yesterday 5 days after my new window was installed I took it by the dealership this morning. Service manager wants it this afternoon. Talked to GMC to reopen my case. And here is a good one for you guys. The guy at GM said he had never heard of this issue. And was blaming the work that the glass installer had done. I had to laugh and then proceeded to educate him. Also pointed out this website for him to look at and gain more education. Of course I think he is lying about not hearing about this before. And no loaner car for me, damn. The adventure continues.
  • Haha 1
  • Sad 1
UGH!  Took my truck in for the seatbelt recall and the dealership found a lot of moisture under my rug.  The source:  Rear window.  The first attempt to reseal the window failed and waiting to see how the second attempt goes.  so far they had to remove and dissinfect my carpet twice now to prevent mold from growing.
They will never fix it with sealant, i dont think a single person has had that hack fix performed and had it last more than a week if even that.
They sealed mine three times before I convinced them that it needed a new window.  Today they removed my window and I found not one but two cracks through the plastic frame at the edge of the slide guide rail. Good Luck.  I'm on day 75 and they want to give the sealant on the new window 48hrs to cure so I won't get my truck back until Monday-79 days out of service.
I have read through so many posts on this topic, most people arent posting the type of rear window they have.  Are folks with the fixed rear window experiencing same issues?  I could care less about the sliding rear window will really never use it.  Wondering if I should just have it replaced with a fixed glass unit.
That’s why I ordered mine without it
That’s nuts they should have compensated you some way or another
Mines been sealant fixed since August. Worked on the first attempt and still dry today. Competence (or incompetence) of the techs doing the job probably plays a huge part. Don’t get me wrong, I’m not happy my window is caulked though.
The caulk joint was very poorly done with mine in the fix each time. I’m actually going to see if they need that window or if they are going to junk it. The pro I saw on the repair after having the window out was the caulk tube tip was cut with too narrow of an opening and wouldn’t allow the caulk to flow out and cover the entire joint from truck body to window glass. Ha they don’t that there would have been no was for the water to enter cracked frame or not. The way the window sits with the spoiler they really would have. A hard time Caulking it properly.  Why GM didn’t have the spoiler come 3/8-1/2” down below the window top and terminate on the glass vertical surface instead of the Horizontal joint is beyond anything this plumber can figure.
Lol, even as a guy who works in music industry, works on my farm, and does extensive home remodeling -- the first thing I thought of was this exact thing -- why in the hell would they run this angle directly for water to hit a seam? Makes zero sense. Water will find a way through the smallest hairline crack. Just common damn sense.
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
    • Looking for a clean way to add serious lighting to your 2019+ GMC Sierra 1500? Our M&R Automotive 40" SLIM Light Bar Kit was engineered to deliver maximum performance while maintaining a factory-inspired appearance.   Features: • Designed specifically for 2019+ GMC Sierra 1500 models • High-output 40" SLIM LED light bar • Clean, integrated grille-mounted design • No cutting or drilling required • Bolt-on installation using vehicle-specific brackets • OEM-style fit and finish   Whether you're hitting the trails, exploring backroads, or need additional visibility off-road, this kit provides powerful illumination without compromising the look of your truck.   For product videos, light output demonstrations, and installation content, check out our YouTube channel:   https://www.youtube.com/channel/UC3lutWP54fkXBl3iFLDJR-A Have questions about fitment or installation? We'd be happy to help.
