My HC doesn't have noise canceling, you can check your headliner to be sure.
3 hours ago, alipor said:
Finally picked up my truck from the installers, turns out integrating with the bose isn't terrible, there wasn't a ton of EQ'ing going on with the bose amp.  Anyway here is the link of the installers build log of my system.  Nick really knocked this one out of the park, it has blown away my expectations.  Nick's attention to small details really separated his work from the three other shops that has done systems in my cars, he was over 2hr drive for me and i'd happily drive further to have him work on my truck.
https://www.diymobileaudio.com/forum/build-logs-project-install-gallery/416775-alipors-2019-chevy-silverado-high-country-semi-stealth-system.html
Hah nice! My Sierra is going into Nick’s shop next week. He told me there was a Silverado in the shop but never guessed I’d read about it here. Great to hear you’re thrilled, although I’m not surprised. I’m not going quite as hard as you did, but I’m excited to get it installed.
Pretty funny you are on here as well, Nick was telling me, when going over my project that someone else was doing a system as well. You'll love it when he is done this I'm sure of.
Did you get your set up installed? If so mind giving us a few shots.
I picked it up Wednesday night. It’s totally awesome. There’s not a lot to see (intentionally) but I’ll try to remember to get a few pics and post more details soon.
12 hours ago, DanHc said:
Just got this box made for my HC for 2 JL audio 10w7 they should be going in next week!
Damn!  That's a gorgeous box.
I just finished my install in my AT4 with Bose system, I spent $390 and it’s sound ridiculously good. I put in a pioneer mono amp D9701 a pioneer 12” SWX3002 that is already boxed and fits nicely under the seat and an audio control LC2i. Install was easy the truck has plenty of space for running all the cables. Has enough space for the amp and the line converter under the passenger seat. I had the Kicker OEM on my previous truck and it did not have enough kick for me.
I tied uploading pics but it only allows me 4.8mb
Finally took delivery of the truck and I will start tearing it down this weekend for measurements to verify fitment. The shop that usually tunes my system will be doing the amp rack because seeing the work Nick put into that high country makes me not want to bother with it. Sound deadening and adding the MLV will probably take the bulk of my time but I can trace out copies of the finished shape for anyone that will want to add MLV which should save you a ton of time. The dash speakers are what I am worried about because I don't want custom pillars so I will have to see if I can fit my current AP drivers in there or have to go another route. Should have a bunch of info and pictures up this weekend
I also got the loop back harness from LLJ Customs, bose amp is located under center console so that where you tap into for signal. Also running an LC7 makes like much easier! Also for adding door speakers there are speaker wire adapters to make life easier. From what ive seen if you dont have bose you just get a loop back harness and it plugs in right underneath passenger side dash.
So I left this for the last minute thinking it couldn't take too long to get measurements and finally got a gap between afternoon showers. Well, i was totally wrong. Going to have to plan this out for a day where I have more time because there is some serious steps to getting to those damn speakers. I will post back once I get to it but for reference, see the steps required and their corresponding document ID's below.
Radio control assembly removal
1.       Remove instrument panel trim (5002230)
2.       Remove floor console extension panels (5001357, 5001302)
3.       Remove console cup holder trim plate (5001449)
4.       Remove instrument panel lower trim (5001641)
5.       Remove radio control assembly (5020726)
Front left speaker grille removal
1.       Unplug negative battery terminal (SIR System)
2.       Remove left side A pillar molding (5132920)
3.       Remove left side instrument panel fuse block access hole cover (5000747)
4.       Remove left side instrument panel pad (5000836)
5.       Remove front left speaker grille (5004265)
Front right speaker grille removal
1.       Remove right side A pillar molding (5132920)
2.       Remove right side instrument panel fuse block access hole cover (5000747)
3.       Remove glove box (5027467)
4.       Remove right side instrument panel trim pad (5002584)
Wasn't aware of their shop. You're a life saver. I was looking for a wiring harness like this.
21 minutes ago, HTX ‘19 Black Widow said:
Is this under your seat?
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
