Must just not work on the Silverado?   I dunno.
I didn't know. I think it works on Tahoes. I found out about it on a Tahoe forum.
From what I understand, It's something the service department does so that the vehicle doesn't shut down during engine test.
Sent from my SM-N986U1 using Tapatalk
29 minutes ago, GTPprix said:
It’s a completely different electrical platform so that’s not surprising.
I'm not getting the pop up message that it is disabled like he showed either.   I don't think Silverado's are equipped.
RhinoGuy - What year/make/mode do you have? I have a 2019 Sierra and the “hold for 15 seconds” thing didn’t work for me.
I don’t see anything that looks remotely like this in the bcm for the pickup. He’s got a Yukon which is a completely different electrical architecture..
It's might be a feature built into the T1 SUV platforms due to the PPV version of the Tahoe...just throwing that out as a guess.
21 Yukon.
Putting the truck in neutral and setting the parking brake may work for you
Sounds like the right fix is that they should just go back to a true key system! Those that want the vehicle to run will run those that don't turn them off pretty simple. I don't know why things need to be complicated.
f*** this auto stop and push button b******* and traction control
(when I turn it off I want it off.. I don't want it to come back on at 35 mph wheel spin) save us all some money.
some of us actually know how to drive and use our vehicles the way that we want them used..... You do you and let us do us.
You can let your vehicle run all day and do your jobs..... For everyone else who doesn't use their truck in this manner you might actually have to use your brain and remember how to turn it on and off and remove the key out of the ignition probably too hard for some....
Sorry for my rant but I'm just tired of the government And big brother imposing everything at a higher cost to us all And then all the sheep that defend them.
It's amazing how and what we do to protect the stupid, And then when they still kill themselves the lawyers win a financial settlement in court for their families yet again costing us more. Smh
Sent from my Pixel 4 XL using Tapatalk
No offense but you're bitching and moaning about something that very small niche of consumers actually want.  Ask 20 truck owner out the in the real world and see how many actually want this specific feature.  It is not stupid people that are killing themselves b/c they forget to turn the vehicle off, saying that is very condescending.  My coworker and his wife were killed b/c they were out of their routine and left their vehicle running, we work in an engineering department and he's one of the smartest people I know.
Super smart people... But yet common sense stupid..... I work at a university and see it everyday, we call them the absent minded professors.
Sorry your friends died. But I see things quit differently.... If you have a key you are pulling it out, no forgetting it then. Talk to any real blue collar worker they will disagree with you, unfortunately, you are absolutely correct that we are there minority.
Yet, we are also the original truck buyers and owners!!
Simple solutions for both sides would be to put in an override or disable options.... Easy peezy! Bitching and moaning minimized for both sides.
Unfortunately those of us that need a truck have to pay for these nano gadgets that we don't even want.
No need to complicate things it's called
k.i.s.s.
Keep it simple stupid.
Have a great weekend, thanks for your "majority" input while the rest of us suffer with the lack of working designs, for working people.
I knew I would come across it eventually, someone posted on this thread:
3rd post by bamorris2
open the file attached,
doc id 5695820.pdf
page 3, top of the page
3. Apply brake and start the vehicle, holding the Engine Start/Stop button for at least 15 seconds.
*   At this point, T1 SUVs will display an "Automatic Shutdown Disabled" message on the DIC.
*   Other vehicles will not display this message on the DIC, but by holding the Engine Start/Stop button for 15 seconds, the feature will still be activated on T1 trucks.
either there's more to it than just that...or this statement in the doc isn't corect.
doc id 5695820.pdf
It cannot be correct.   I've tried it several times, as numerous others have.
Agree.. either the doc is wrong or were missing something.
It says hood open. Maybe the hoods gotta be open so it thinks it’s getting worked on? Anyone try it that way?
I just read the actual bulletin.  It may have more to do with the laptop module being hooked up to it too, on that way of thinking.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
