Chevrolet Illuminated Grille Bowtie Emblem in Black Part Number: 84069488
The Merva Brothers
Founders, GM-Trucks.com
February 27th, 2019
When you take delivery of a brand new 2019 Silverado, you'll be faced with a few choices beyond which trim level or options you want. You'll also be asked which accessories you want to be installed on your truck before it rolls off the sales floor. Most GM accessories can even be factored into the sale price and financed. So, we're setting off to try out some of these certified accessories that are available for the 2019 Chevrolet Silverado. Our goal is to let you know if they are worth the cash or if you should take a pass.
We've always loved the look of a blacked out bowtie and the idea of one that lights up seemed too cool to pass up. So we headed to our local dealership and ordered the 2019+ Illuminated & Blacked out front bowtie. Here's how it went and what we think.
What is it?
MSRP: $275.00
Manufacturer Website: https://accessories.chevrolet.com/
Main Features
  • Doesn't effect your factory warranty
  • Direct replacement for the standard gold bowtie
  • Same quality as original parts
  • Wiring harness is plug & play and matches factory wiring
Here's the bowtie and grille as it came from the factory.
Installation
The first step to install the illuminated bowtie (or the non-illuminated black bowtie) is to remove the front grille. The grille on our LTZ was easy to take once we understood how it was fastened to the body. The entire process runs around 30 mintues  We'll be covering how to remove the grille on the 2019 Silverado in detail soon.
A plastic trim removal set makes this process much easier.
After a little bit of pulling and careful prying, the entire front grille section comes off. Note the grille can be removed without having to take off any body panels or reach under the vehicle. This is a huge improvement over past Silverado generations, which required more disassembly to access the grille mounting hardware.
The grille is a solid unit. Switching it out with another trim level's grille would be easy at this stage. This is also a good time to clean up the grille.
To remove the factory bowtie, release four tab clips on the backside of the grille. One is inside of the support post where you will also run the bowtie's wiring harness.
We popped out the bowtie and cleaned behind it before installing the new one. It was filthy underneath!
Chevrolet Illuminated Grille Bowtie Emblem in Black Part Number: 84069488Chevrolet Illuminated Grille Bowtie Emblem in Black Part Number: 84069488
The included wiring harness plugs into the driver's side headlight harness. It then snakes through the radiator opening and clips to the bumper. We found it easier to run the wire through the grille and connect it to bowtie, THEN snap the bowtie to the grille afterwards. Attempting to plug the harness into the bowtie after it is mounted on the grille turns out to be extremely difficult.
We tested the bowtie to make sure it lit up properly before we attached the grille back onto the truck.
Our Impressions
Installation of the illuminated bowtie turned out to be pretty easy provided we used the right tools. Our plastic trim kit was invaluable during the process, allowing us to pry and remove pieces without scratching them. The kit also didn't come with instructions, so make sure to ask your dealer for a set of them when you buy it. They can print it out for you.
The quality of the bowtie is on par with other factory parts and matches accordingly. The wiring harness looks similar to those already running under the hood giving the final fit a factory feel.
So while the look and feel of the product is excellent the actual performance of the illuminated bowtie left us wanting more. We expected an illumination effect with a similar brightness to our DRL lighting. Instead, the bowtie glows a dull white at light. During the day or bright sunlight the illumination effect disappears completely. We do appreciate that the color temperature of the bowtie matches the headlights and DRLs.
The MSRP of $275 is steep for the eventual lackluster performance. Excellent build quality, plug and play performance, a factory look, and no warranty interference offset the price to an extent.
If you want a quality replacement for your gold bowtie that adds a little more flare to your 2019 Silverado, the Illuminated Black Bowtie could be right for you. If you're looking for a bright centerpiece that stands out with the same intensity as your other lighting, this may not fit your bill.
Zane,
You guys have a damn fine looking T1 LTZ !
I think the illuminated bowtie was designed to be lackluster in a safety way.
Subtle enough to be pronounced..... but not overpowering. It is a nice touch.
Great writeup. Keep up the good work :thumbs:
  • 5 months later...
And I was really looking forward to getting the same illuminated bowtie for my truck too, but having now seen the level of brightness I am having  second thoughts.  Thank you for the write up.
Pretty neat, I too would prefer brighter but understand the safety of it being too bright....thanks for the insight and feedback for all members here !!!
  • 3 years later...
  • 3 months later...
Transform your 2019 Silverado with Chevrolet's Lighted Bowtie, adding a touch of intrigue to your ride. Illuminate the night with a nod to iconic design. It's like adding a jumpscare from Fnaf to your truck's front end
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
