I want to link a thread I started that has some information that people are looking for here.
Eli
If anyone is looking to buy this system, part number 19417165 for the non-Bose system, retails for $1250. I removed mine along with the Infinity Kappa speakers with door and harness adapters for all four doors from my 2020 Trail Boss before I traded it in for my 2021 AT4. $1000 for everything. Located in Michigan and will install it if you come to my house but willing to ship at buyers expense. Text me at (989)450-6058 or email [email protected]
Does anyone know the impedance of the kicker sub? I am having an issue where the amp intermittently shuts off. Sometimes for only a few seconds sometimes for a few minutes. I'm thinking I might just replace the amp but finding the kicker amp that comes with the system has been a lesson in futility. I need to know the ohm load of sub in order to pick the correct amp.
I just picked up the kicker sub and hope to install it in my AT4 with Bose this weekend.  This thread should be helpful.
How’s it sound?  I just bought an AT4 last week and bought the Kicker amp plus powered sub kit.
Honestly, I'm a little disappointed.  I was expecting more.  I connected the Kicker Amp to the factory Bose sub inputs and it was barely noticeable.  I had to increase the gain all the way to get a noticeable output.  The base is very clean, but it doesn't hit or thump like I was hoping.  I might go back in there and switch the polarity to see if that makes a difference.  If not, I'm going to try and connect to the forward right speaker like the instructions say to see what difference that makes.
I have a 2021 1500 AT4 NON-BOSE system.
Dropped my truck off at Dealer today to install the kicker powered-Subwoofer AND the second amp (part 19417165).
They called 4 hours later and said the Kicker powered sub PLUS the second amp won’t work in my truck.  This is part 19417165.
WTF?
They said I can only use the 19417164…which is the Sub only system.
Is this true?
Edited by Gmoeller
Details
That is strange you should get a second opinion at another dealer or a good stereo shop with a good rep. They probably didn’t feel comfortable installing it.
WTF?
Is this true?
There are two different sub plus speaker amp kits - one for the IOR stereo and one for the IOS stereo.  Think the part # is 19417166 for the IOS system.
The part #19417166 specifically says not compatible with IOS system.  And I have the IOS system. 😞
But thank you for responding.
Edited by Gmoeller
I see just the opposite when I look them up.  Interestingly though, it doesn’t show up as an option for ‘21 trucks but does for ‘20 and prior years - I didn’t think ‘21’s were any different than ‘20’s but who knows.  Might be worth a call to Kicker to clear it up.
Edited by RCF71
I installed the 19417165 two amp system in my new 2022 TB Ltd.  I am very happy with the sub but not impressed with the second amp for the front speakers.  Also I have to adjust the balance over to about halfway to the left to equal out the left and right front speakers.  Did anyone else have to adjust the balance on to get the fronts equal?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
