I've already debaged the tailgate, and thinking about removing the bed side vinyl decals. Has anyone done this?
Sent from my Samsung S10+ using Tapatalk
I want to debadge the "Silverado" from the back of my truck and change it to "Cheyenne" but still have to find the correct 2019 emblem.
Y'all bought the expensive Trail Boss and then proceed to remove all references to Trail Boss?  Why not just buy an LT and install a lift kit and tires/wheels for less $?  Or if $ is no object, get a High Country to get the 6.2L and then lift it??
  • Haha 2
  • Confused 1
There’s a guy on here who just bought one and removed the decal. Hopefully he’ll chime in.
@MaverickZ71 if the only thing he doesn’t like is the decal / name (I don’t really either), it makes a lot more sense to take a decal off than it does to try and build a Trail Boss out of an LT. You wouldn’t really be financially ahead by much, if anything, and there’s options on the TB that the LT can’t get anyway....Bose, buckets, blackout trim, etc.
I'll be getting a Leer cap so the lip from the cap will probably overhang the TB sticker so I figured it would be best to just remove it.
I peeled the 4x4 ones off of my bed. They come off cleanly. Just lift a corner with your fingernail and then, pull it back over itself. So that the edge coming up, rolls back as you pull it. I went slowly and they came off in one piece, leaving virtually nothing behind. I wiped it once with a rag that had some goo gone on it and then washed it. Easy Peasy.
took mine off in a walgreens parking lot waiting for my wife the first week i had the truck.
  • Haha 3
Looks good, now you need to clean up that tailgate!  I debadged my LTZ the first week.
PS: Would you mind telling me what running boards they are?  I like the simple look of them.
Those are the gm 6 inch black rectangular oem running boards. So much better then the 4 inch tubular gm boards on my last truck.
Limelight, if you’re keeping the chrome trim, you might take a look at the domed chrome lettering I set for your tailgate lettering. I think it looks very nice.
Peeled off fairly easy. Let sit in sun for awhile peeks off easier. Looks cleaner. Now the Silverado and LT badges are next.
What is this sun thing you speak of? Have not seen that in 4 months.
I always wanted to down-badge my 6.2L to a V6 and go make some Hemi's and F150's cry mercy. Peel it off, any decal shop can recreate it for you if you change your mind down the road.
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
