3 hours ago, Grumpy Bear said:
It's already at 375 kPa (54 psi). Indy car territory. I'm thinking it's tapping out as is.
If you look at the boost curve it's on the limiter from the hit.
Not sure where you saw that at. It runs up to 22psi of boost. It’s not really pushing any design limits - GM wasn’t stupid enough to stress it like Ford does with the EB.
Gorehamj's post which I see I read incorrectly. I read that line at about 200 kPa or 29 psi. My bad. Thanks for making me look twice. :thumbs:
Edited by Grumpy Bear
Haha no worries - what an interesting chart.
I will say that from my butt dyno and audible perspective that it is spot on. The turbo spools (and starts whistling loudly) right off idle. My neighbors used to be able to tell when I was coming up the road from the exhaust on my Colorado - now they can hear me whistling up the hill.
  • Haha 1
Anybody else hopelessly waiting for some performance mods to come out for these 2.7's?!
Have a question regarding the 2019 GMC sierra. In the center of the dash board, in front of the catchall is a square domed area (between the catchall and the windshield). It is about 1.5" square. What is it?
Light sensor for the auto headlights.
Anyone else with the 2.7 having 8-speed transmission Issues? I still have a harsh shift 1-2 and 2-1 after getting the new transmission fluid.
I have the occasional rough 1-2, the occasional 2-1, and it shudders like a wet dog pretty much all of the time under light acceleration. The 8 speed is Satan's own transmission and needs to be recalled, taken out back, and shot...
On 4/5/2019 at 8:53 AM, the wanderer said:
I suspect that little 2.7 gets better MPG than EPA. TFL Truck tested it and got like 25MPG on their Highway loop. I'm seriously considering it, but the reports of turbo lag at highway speeds does not bode well.
I plan on pulling a trailer, nothing more than 5 to 6 thousand pounds so it would work there, but I don't know. My gut tells me to let them work out the hiccups in the motor first, and fix that lag issue before I'd consider owning one in a truck I hope to keep 10 years.
The 5.3 is not that powerful compared to competition, but it's bullet proof for the most part.
I know this is an older post, but I pull a trailer in the 5 to 6 thousand pound range and my 5.3 was straining when crossing mountain ranges.  And the trans temp was over 200° going uphill.  No way would I ever try to tow that much with the 2.7 unless it was short distances over flat terrain.  That's the whole reason I upgraded to the 6.2 and max trailering package.
Turbos get a huge benefit over NA vehicles crossing mountain ranges. If you were crossing the Rockies, you were probably down over 30% of your horsepower.
HP Loss = (elevation x 0.03 x horsepower @ sea level)/1000.  7000 x .03 x 420/1000 = 88.2/420 = 21% loss.  I'm still pumping out more horses than a 2.7.  I imagine it's the same for torque.  And I have that 3.42 rear end.
Edited by AlaskaErik
    LCH14
    LCH14
  • Who's Online   5 Members, 1 Anonymous, 768 Guests (See full list)
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
    • With this new pan, do you still use the same procedure to check the level? Its a deeper pan and our trucks do not have a fill tube/dipstick. So fill till fluid runs out the check plug?
