6 hours ago, Matty Patty said:
@truck_newbie
I have a 01/19 Mexico Truck with the AAJF SU4 American Axle GM part# 84605752 one.
Will take a picture of mine and compare.
I've got a High Country with 15K and change on the odometer and the SU4 front axle and have not heard a peep.
I've gone under the truck and there is the slop/play where the axle goes into the diff (just like the video in the beginning of this thread) but no noise.
I've been following this thread simply because I don't think that slop should be there and can't be good for the longevity of the drivetrain despite the assurances from GM.
Same as you except I’m only at 4100 miles. The CV shaft play is present at the axle but I have no noise either.
The amount of play is small but I agree, I don’t think it should be there either.
For the people having the noise problem, it does go away when 4WD is activated. So I wonder if the play exists when the shafts are engaged.
I just checked too and at first thought no play but shook a bit harder and its very small but play is there - in and out - up and down.  I have a 19 LT TB Fort Wayne SU4  7/22/19 with 600 miles and absolutely no noise yet.  Guess I'll keep watching and hopefully a permanent GM fix in the works for current and future jingle events.
Per my past posts from pages ago, I’ve checked about 10 other trucks on the dealer lot, LTZ, LT, RST, TB and they all had the same small amount of play. Even the SU5 GM axles had the same amount of play and they are not even affected.
I’m thinking about going to crawl under a few Rams, F-150s, Tundra on the lot and see what their CV shafts are like.
Are these the part that is causing the jingle?  Here are my two and so far no noise bu less than 700 miles.
My other...2019 LT TB
I decided to take a picture of my differential since they’re going to replace it. Once I get a new one I’ll take a picture of that to compare
good evening all  well they have decided to replace my differential also as of today dont know when they will get one so in mean time i am going to get my truck and drive her til they have one i will also take pics for comparrison
@pearlymae19 @Thejet07 keep us updated on whether or not the new diffs fix the issue!
Knock on wood- I have been driving mine with the "fix" for 5 days and jingle has NOT returned. Hoping I didn't jinx myself.
My truck goes in on Monday. Don’t know how long it’s going to be there for and unfortunately I may not be doing much driving due to a recent injury. Fingers crossed all goes well and I’ll definitely keep you guys posted. Funny thing happened today. My radio has issues with going black or getting stuck in night mode when it’s daytime(radio replaced and still same issues). Anyway, the touch screen became totally unresponsive. Tried shutting the truck off and restarting. Nothing. After driving for ten minutes or so and pressing the screen a thousand time a screen popped up that said if your a passenger to accept or decline(something to that effect) came up and it suddenly became responsive again. Very strange but not surprising. Sorry for going off topic. Anyone else had this issue?
Similar thing happened to me recently. Screen froze, I tried pressing different buttons and nothing. Then screen went completely black. Shut truck off and then on, nothing. Turned truck off, went to the store, came back 20 minutes later turned on truck and everything started working again like nothing happened. Weird
hi all  picked my truck today without the fix because of strike they dont know when a differential will come in  i also was told by advisor that my front and rear suspension has all been rebuilt  what exactly all that means is my guess??  he said they will beout of options if the differential does not work so i asked if it would then be called a lemon  but that was where he stopped  his comment was he did not know about lemon laws  anyway thats the latest that i have   will try and get some pics before they mess with her again  will keep you all posted and thanks so much for all the info
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,136 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
