Our truck with only 6,200 miles bent a pushrod already.  We are concerned as the dealership already had a notice of the known issue.  They fixed it but worried it was not a real fix, just a replacement of the defective design. Has anyone else had this problem on the new 2019 Sierra 6.2L.  Would love to know how big an issue this is.
Nope. Im at 6200 too. No issue as of now. If that did happen Id just have a set of 11/32” .095 wall pushrods made in the correct length vs dealing with the dealer/GM.
6800 miles on my 62, so good so far!
55 minutes ago, SkiDooNick700 said:
Seems the issue is still there even from the L86 in K2 trucks lol. Fantastic.
Because the engines are the same architecture.
Only real difference is instead of shutting down 4 cylinders with (AFM)  L83, L86...… the T1 engines
with (DFM) L84, L87 can run on as little as 1-2 cylinders.
Right... so is it a design flaw then in engine architecture or defective parts? Or just a one off?
Anything mechanical can fail at any point in time.
GM has cranked out hundreds of thousands of these L83, L86, L84 and L87 engines since 2013
I would say yours is an exception to the longevity of others out there.
If it were a design flaw we would be hearing this from other members daily I suspect.
As they say, S*** happens.
8600 miles. No problem with 6.2. averaging 17.4 mpg. Skewed a little because of a long FL trip, and one to NC OBX. I was averaging 16.5 with about 50/50 highway and rural/city.
  • 8 months later...
I have a 2016 Yukon XL Denali 6.2l  that bent a pushrod at 67,000 miles (just out of power train warranty)  Replaced the pushrod and rocker arm.  Now at 71,000 have 2 stuck lifters and a dead cam.  Dealer wants $4,100 to repair, but GM will pay 25% because I am a "valued" customer!    Pretty crappy for an $80K ride.
  • Sad 1
WOW! Last time i heard this was on my 2001 Camaro LS1!!!!  Good luck brother!
How did you manage to do that on a LS1 Camaro?  Good grief!  What were you doing!?
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
