Tire rotation every 7500mi
For all of you who rotate your own tires, do you follow the direction indicated in your owners manual?
When I do mine , I leave the spare out of the rotation, and simply put the front tires on the rear and the rears on the front.
I work the right side first, then the left.
Whats best and why?
Who has a spare that match's?  Mine does not, wheel is different, tire its different.  Only good for a spare.
That is true!  You get 4qty Absolute garbage tires from the factory and what is underneath?  Surprise a even Crappier tire!
rearward cross.
that way each tire get to experience each location on the vehicle and should distribute wear equally between them.
Image result for rotate tires direction
9 minutes ago, aseibel said:
rearward cross.
Yep, rearward cross is the best.  Keeps everyone wearing evenly!
Hahaha, I know right? My spare is a steel wheel 265/75R17 lol...It will look awesome running with my 275/55R20's on the other 3.
I’ve got directional tires on mine so I can only go front to back. I rotate mine every oil change which I do every 5,000 miles or 6 months, whichever hits first (usually 6 months).
I rotate mine every 5-8k depending on when I get ambitious. I go by the manual which is apparently different than how tire shops rotate duallies. The only reason I don't rotate the spare is I don't feel like messing with the spare tire carrier. Since I have 7 steel rims they're all the same so that's not the issue for me. I try to do it around the same time as my oil changes. Rotations are easy and I know that the lug nuts are being torqued down to the proper 140 lb/ft. Unlike some places that require me to use a cheater bar on my cheater bar to get the lugs off.
Sent from my Find7 using Tapatalk
Thinking the same thing, my truck would look pretty sharp with 3 22's and a 17 for 20000 miles until it worked it's way out of rotation.
While we're on the topic, anyone know of a decent TMPS programmer so the display on the dash shows which tire is which correctly after a rotation?
 I was about to ask the same.  I saw a few on Amazon, but none of the "affordable" ones have great or even consistent reviews when it come to working with an 18 Silverado.  If anyone has one that is proven to work on an 18, please speak up.
I’ve got one scratched up 20 inch snowflake now, so when that scratch drives me crazy enough that I feel I need to go extreme and do something about it, maybe I’ll put that on as a spare. Still looking for a good wheel guy to do wheel repair. Fix the scratch or get a new wheel. Whichever comes 1st!
I use the EL-50448 OEC-T5, I have used it on my 2016, not sure what you guys think is different they are 314.5/315MHz or 433MHz if you had a strong enough magnetic it would work as well.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
