I really wanted those steps but now the boss says Santa is gonna bring Amp research steps for Christmas.
I am sure this has been answered already but just wanted to verify before I placed an order. Will a 2" lower mount front level kit (rough country) fit a 2019 gmc sierra SLE? So not factory lift like the AT4 or anything like that.
Looking at ordering this for the front:
https://www.roughcountry.com/gm-leveling-lift-kit-1307.html
And this for the rear: ( I looked and it appears I have a block already in the rear, so could I do a 2 in block to maintain some rake?)
https://motofablifts.com/i-30558232-2-rear-leveling-lift-kit-for-2007-2019-chevy-silverado-sierra-gmc.html?ref=category:1390569
Would this cause any issues?
Edited by jordanl010
Yes, that will work for your gmc.
Awesome! Thanks for the help. I have been diving into this forum as I just got my truck Wednesday last week so still researching my options. Would there be any issues that anyone can think of going this route? Would I need strut extensions or anything for the back?
Where can I find a 1" rear block for my '19 Silverado? Motofab only has for old body style. Rough country does not have them either?
For all you DIY guys, where did you place your jack points? Pictures would help. I see the circular plates and read through the manual but its just side by side. Using a standard floor jack and research, not sure without an adapter, I can't seem to figure it out without trial and error on my new truck ?
On 8/9/2019 at 12:41 PM, Bluerado23 said:
2” ready lift front only
315/70/17 ko2
17x9.5 wheels
Any issues with the Ready lift?  I'm looking at doing the same.  Rough Country keeps getting thrown around by my installer.
None at all, that’s what my local dealer had in stock when I purchased the truck so that’s what they put on.
I had rough country on my 15 duramax with control arms and shocks all around I never had any issues with that.
I do have to say I did it for budget reasons and temporary lift, if I had everything may way I would just do a bds kit
Or some type of coil overs and control arms
Okay.. so after reading all this.. how much rake do the trucks really have?  1.5" or 2"?  Are they different between models?
Thanks
Thanks
2.5” on my AT4.
Which left me with a 1” rake after motofab 1.5” spacer added.
On 9/17/2019 at 7:09 PM, Ezekiel2517 said:
My LTZ Max trailer has 1.25" take
My LTZ with 6.2 and trailer package has a 1.25” rake as well. I figure the 2” level will be way too high.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 526 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
