On ‎8‎/‎22‎/‎2019 at 3:51 PM, Chance1025 said:
FWIW, I measured my trail boss before and after my 1.5” motofab. By my measurements it was exactly 2” lower in the front. Put on the 1.5 and low and behold, it raised it 1.5”. Haha.
Kinda wish I would have went with the 2”, because there is still a hair of rake. So to those who haven’t yet, always measure first!
My LT Trailboss has about a 2" rake... sounds like the motofab 2" kit should work... but wondering if I should play it safe and go with the readylift kit with UCAs...
It seems like 2" front levels have little involved with them.  The 3" front levels from RC and Superlift require spring preload spacers.  Does anyone know what a 2.5" lift would do?   Would it just be a plug and play spacer like a 2".  I saw that the pro-comp kit split the spacers between top and bottom.  Wonder why they need to do that.
Is 3" the magic number where differential drops, CV angles and UCA angles get out of wack?
On 9/27/2019 at 5:31 PM, tannerm24 said:
My LTZ with 6.2 and trailer package has a 1.25” rake as well. I figure the 2” level will be way too high.
Motofab 1inch lift will fix it. My trailboss has a 1.5 rake going 1 inch lift.
Local install guys get a LOT of business and they’re putting 2” on everything. They don’t even have a 1.5”. They tell me the 2” levels them all almost perfectly. I don’t see how that’s possible if some trucks, including mine, only have 1.25” rake.
I have a rough country 2in level on my 2 wheel drive LT 5.3 l and it looks good but from what I've seen and read online I think it takes less than 2 inches for trail bosses.  If you look on the wheel and tire thread there are people who have done less than 2 inches leveling.  There's a picture of my truck with the 2 inch level and Nitto Terra Grappler G2 295 60-20 tires.
A lot of trucks do have 2 or 2.5 rake, but some of them like you and me and others have a lot less. No idea why but I'm not complaining because the less i have to add the less stress on front end parts. Trailboss already has 2 inch so adding another 1 puts me at the magic 3 inch number which they say is max before you need to change out the arms.
Alright may be a stupid question but what is the best place to measure for rake? Just from the ground to the bottom of the fender?  I measured mine today and have a 3/4" rake so a leveling kit I already bought for it will put it way to high in front.  Could do a block in back, is there any reason or any negative feedback  of having a block in the back?
Not a stupid question. It doesn’t necessarily matter where you measure from as long as you do it the same way on the rear as you do the front, whether it’s from the fender to the ground or fender to the top of the wheel. Although mine is showing 1.15” of rake, I’m going with the 1.5” level. If it sits higher in the front, I’ll add a block to the rear. Either way, I’ll be switching to Bilstein 5100’s once they’re released.
Here is 3" kit on my 1500 Sierra. It now measures right at 40" in front and 42.5" at rear with the 33" tires,285/70/17" to the
Bottom of the wheel wells. Sits about the same as factory 2500HDs. Not even close to rubing anywhere. Rides and handles nicely. Get alot of " oh you bought a 3/4 ton?" Comments all the time. I am pretty sure 35" would have worked just fine. But I didnt want
to loose that much mileage.
Edited by 2019 Sierra Me
Made my order!  Got some 2" top mount motofab spacers and some 1.5 rear spacers on ebay.  Ordered the motofab rear shock extender as well.  The other cheaper ones looked, well, cheap.  Hope to get it on in next few weeks.
Edited by Ezekiel2517
How the ride quality on that set up, I’m looking at doing something similar on my 2wd RST. Also do the tires stick out any on the sides? Any rubbing issues?.. Sorry for the bombardment of questions but I’m new to the truck scene. Thanks
Motofab 1.5” level.
35/11.50r20 Ridge Grapplers.
No offset. No trimming. No rub.
Make sure to measure your rake. I had the 1.5” level installed and it’s perfectly level. 2” would have been too much.
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
