Spark Plugs and Wires Replacement/Upgrade
Darksky
(I searched the forum to no good answer)
My 2015 CCSB 4WD Silverado 1500 L86 6.2L  has about 65,000 miles on the clock. I’m considering replacing the spark plugs and wires during my next maintenance day. It is not missing, but the idle isn’t as smooth as it has been, it might have a tiny pause upon acceleration. I’m pretty conscientious regarding maintenance and have serviced the intake/fuel system regularly, so this seems like a logical progression in scheduled maintenance.  No big engine mods done, intake and a muffler is about all.
1. Is it appropriate at this mileage and hours/age?
2. Which products have you used and why.
3. Costs and potential bargains.
4. Tips or Tricks to make the process easier or provide a better outcome.
thanks for your input and sharing your experience. If you recommend parts, try and include parts numbers.
Thank you, Dark.
In my working years the last time I changed plugs was 1994. I would trade every 2- 21/2 years usually 150K miles. My longest was 2004 Z71 at 180K, needing no change. With that kind of service I would go OEM.
Stick with the OEM AC Delco plugs, no reason to change it up. I think the part number is like 41-114. Any parts store can look up the OEM plug option and you can verify it too on various websites. Should be around $7-9 per plug.
With that low of mileage I wouldn't even replace the wires but that is just me, I'd clean the ends and put new dielectric grease for good measure.
It's not a hard job at all, just takes time. The back two cylinders on each head can take the most time because of how far you need to reach.
I changed mine at 28K. Way early I know. But I don't wait until 40K to change my 40K tires either. I like things to be closer to optimum. I also went with the Taylor 10mm fatty plug wires. Mostly for looks. But I did notice a minuscule improvement in throttle response off idle. I get bored ;)
409. Had to shed the aluminum shields and springs. But no longer needed.
I just replaced the factory plugs in my '14 yesterday at 97,200 miles. They still had a good gap of .040".  But they needed replaced.  I went with a Denso Twin Tip Iridium plugs.  The truck runs a lot better and smoother.  I mainly notice it when driving in heavy traffic. I wish I changed them out earlier.  I should have done a 75k internal.  But then again my truck has seen heavy city commuting daily in the heat, tons of idling on construction sites for hours on end with the a/c, towing etc.  It's basically been used in a commercial vehicle sense.  The past few months my MPG has gotten unusually worse on my work route.  So far with the new plugs my MPG is back up to where it should be. So I don't buy this 100k mile business. I had a 2009 Lincoln MKZ with the V6, which also showed 100k plug interval....   again, heavy use for work, and I had to replace them at 70k because the car would not start on the first crank in the early mornings when cold.  After the plug change the car ran perfect up to 100k when I sold it.  These 100k intervals are for a vehicle on rollers in a lab, or ideal conditions, not a 1.5hr 25 mile commute in 100*F weather everyday, or idling hours on end like a wood stove with the a/c on. It was $56, change the plugs.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
