Hello Everyone,
I'm installing wheel well liners on Blanco. Ill make a very basic video on the installation, sound before and after.
Nice. Good call. I think liners are a must have accessory. They make the truck look a lot better, not to mention the great protection they give.
I put them in my TrailBoss a couple of weeks ago. Then put some in a friends TrailBoss a few days later easy install and look great plus the added protection.
3 hours ago, BlancoSilverado said:
Hello Everyone,
I'm curious to see the video.  I'm thinking about using my credits to get them.  Thank you!
Also, Amazon sells the little frame plug caps for those annoying holes that you see on the frame at the back wheel. Pretty inexpensive for one set and they just push in,. The wheel well inserts are great for soundproofing as well
You have an Amazon link? The ones I see say dont fit my truck
Alright i installed them, i did a video from inside of the truck on the same route and did not hear a difference in the audio (so i will not post them). I will put a How-To up on the site soon (well hopefully soon). overall fairly easy to install.
A good T10 and needle nose pliers are your friend for this installation.
Picked up a '19 Z71 this week. ( :) ) , and already have a tonneau cover and running boards on the way.
I will be putting rear wheel liners in, but still unsure if I want to go the felt oem route, or aftermarket plastic.
I see TB75 sprayed the inside instead, which I also thought about doing.
I'm having thoughts of getting OEM felt's and coating them with a few coats of aerosol truck bed liner before installing.  Wondering if that would make them easier to clean (Michigan salt), while still helping with sound.
Thoughts?
Edited by Cohocarl
On 7/3/2019 at 9:31 PM, Trailboss75 said:
I had mine sprayed, much better than a felt liner.
If you don’t mind me asking How much did that run you?
Thoughts?
I know for the small amount of dirt/mud that gets on the fronts easily comes off with a hose. I do not believe that you need to coat them IMO.
Second this.  Mine came out great.
That does look nice.
Thanks.
Hey man, yep I paid $200 to have it done.  I tried to find a Line X dealer around me that would do it, but none of them did.  So I found a local truck shop, but they used a Raptor liner instead and followed up with a clear coat.  Looks great and super happy with the outcome!
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
