22” Chrome 6-split spokes on stock tires. Reverse leveled with belltech 6403 shackles.
On 10/10/2020 at 6:38 PM, JeffC said:
2020 Trail Boss , Eibach pro lift (Level) , 275/65/20 Ridge Grappler , Fuel Rage 20 x 10
What offset are you running?
2020 HC with GM 2" kit, and Bilstein 5100's set to 1.1" so it's basically a Trailboss that's close to level.
285/65 20 BFG KO2s  (34.6"x11.2") on Raceline 20x9 0 offset and 6mm spacers to make the wheels clear the brakes.
Removed brackets and trimmed the mud guards.  slight rub at full lock, but really minor.
Forums like this really helped me figure out what I wanted, and what was possible - so thanks all.   Hope this helps someone else.
been searching allll evening but hoping you fellas be able to tell me or point me the right direction with tires... I just purchased 2021 chev silverado 1500 high country duramax. Don't really wanna put a level kit on it as I love how it rides.
Looking for a good tire setup to keep the comfort ride
I just ordered FUEL OFFROAD CONTRA RIMS 20X9 WITH PLUS 2 OFFSET..
***Wondering what tires you recommend that has good look to them and has a good lasting ride  and what size could I run for tires?? I been seeing alot of bigger tires on the stock rims but as I said I went with a plus 2 offset trying to see what my options are??
My second set of Ridge Grapplers. I have them in 275/60. I like an aggressive looking tire but don’t want the noise. If these are a little too aggressive for your taste look at the Toyo AT3 or Falken Wildpeake AT.
Wow thank you so much..  was needing someone to have a familiar setup. So your have the same offset? With no rubbing or issues ?
Yup same +2. No spacers. I had them on before I leveled and no rubbing at all.
Anyone on here with 285/70r18?
Nearly a 34" tire,
Just ordered my fuel anza 18x9 1mm offset wheels.
Was originally getting 265/70 but figured only 1/2" taller wouldn't look any different. Now I'm half nervous the 285/70 is too fat.
I am planning on a 0.75" level to my AT4
Sent from my SM-T830 using Tapatalk
Pardon my stupidity here, but what is a reverse level ? Still learning all the truck terminology.
Correct. It is a reverse level. Truck is pretty much square. I am working on a write up on what I did.
He dropped the rear instead of raising the front.
Interested in seeing this write up
Yes. What he said. Sorry I thought I put that in my response. Must have deleted it.
I have most of it drafted up. I still have a couple more kinks that I am currently trying to work out on the auto ride mess.
Just got my new wheels and tires installed. They are 35x12.5 Nitto Ridge Grapplers on 20x10-12 Wicked Off-road wheels. I also added a 4” Zone lift to my existing 2”.
  • Like 4
    B07
    B07
  • Who's Online   2 Members, 1 Anonymous, 833 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
