22” Chrome 6-split spokes on stock tires. Reverse leveled with belltech 6403 shackles.
On 10/10/2020 at 6:38 PM, JeffC said:
2020 Trail Boss , Eibach pro lift (Level) , 275/65/20 Ridge Grappler , Fuel Rage 20 x 10
What offset are you running?
2020 HC with GM 2" kit, and Bilstein 5100's set to 1.1" so it's basically a Trailboss that's close to level.
285/65 20 BFG KO2s  (34.6"x11.2") on Raceline 20x9 0 offset and 6mm spacers to make the wheels clear the brakes.
Removed brackets and trimmed the mud guards.  slight rub at full lock, but really minor.
Forums like this really helped me figure out what I wanted, and what was possible - so thanks all.   Hope this helps someone else.
been searching allll evening but hoping you fellas be able to tell me or point me the right direction with tires... I just purchased 2021 chev silverado 1500 high country duramax. Don't really wanna put a level kit on it as I love how it rides.
Looking for a good tire setup to keep the comfort ride
I just ordered FUEL OFFROAD CONTRA RIMS 20X9 WITH PLUS 2 OFFSET..
***Wondering what tires you recommend that has good look to them and has a good lasting ride  and what size could I run for tires?? I been seeing alot of bigger tires on the stock rims but as I said I went with a plus 2 offset trying to see what my options are??
My second set of Ridge Grapplers. I have them in 275/60. I like an aggressive looking tire but don’t want the noise. If these are a little too aggressive for your taste look at the Toyo AT3 or Falken Wildpeake AT.
Wow thank you so much..  was needing someone to have a familiar setup. So your have the same offset? With no rubbing or issues ?
Yup same +2. No spacers. I had them on before I leveled and no rubbing at all.
Anyone on here with 285/70r18?
Nearly a 34" tire,
Just ordered my fuel anza 18x9 1mm offset wheels.
Was originally getting 265/70 but figured only 1/2" taller wouldn't look any different. Now I'm half nervous the 285/70 is too fat.
I am planning on a 0.75" level to my AT4
Sent from my SM-T830 using Tapatalk
Pardon my stupidity here, but what is a reverse level ? Still learning all the truck terminology.
Correct. It is a reverse level. Truck is pretty much square. I am working on a write up on what I did.
He dropped the rear instead of raising the front.
Interested in seeing this write up
Yes. What he said. Sorry I thought I put that in my response. Must have deleted it.
I have most of it drafted up. I still have a couple more kinks that I am currently trying to work out on the auto ride mess.
Just got my new wheels and tires installed. They are 35x12.5 Nitto Ridge Grapplers on 20x10-12 Wicked Off-road wheels. I also added a 4” Zone lift to my existing 2”.
  • Like 4
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
    • Did this ever get solved?   I'm chasing 2021 Yukon Denali electrical issues - vehicle will not enter sleep mode - we can disconnect and reconnect the battery and it will sleep - but that's likely because we powered down whatever module doesn't correctly sleep.  once we start/accessory the vehicle and turn off, it will stay at 11.5 amp draw with something keeping the SDGM alive - it appears to be activity on the X2 segment, specifically CAN FD Bus 5 - but we don't know which device and we think we've already isolated all of the devices on that segment - so what keeps the BCM and/or the SDGM alive is unknown.   I don't yet have a packet trace from CAN 5 (and since this Global B we might not get much info from it) - but the vehicle has been down for 8 weeks and previously GMC Dealer was unable to resolve "kills battery" issues with this particular vehicle - so I'm at a loss - it seems to be beyond local repair capabilities - and the number of "telematics keeps vehicle from sleeping" posts indicates this whole architecture has major issues - I hate to say it, but we might have to install a battery cutoff switch on the front grill - one of those red boat switches - to turn off the vehicle.;)  Any pointers appreciated;)  I just bought a CAN FD interface and I'm planning to try Savvycan and Peak Can SW to triage this further.
