9 hours ago, afterburner82 said:
Fuel Rage 20”x9” +1 offset w/305-55r20 Amp Terrain Attack tires on 4” Readylift SST. No rubbing or modifications.
Looks great! Have any side shots?
Does anyone know what size spacer I'll need to fit the CK160 wheels on my 2020? The company that sent me the wheels said 1/4" would be enough but its not clearing the front calipers.
Edited by Tbaem
On 1/19/2021 at 11:26 AM, MeximusPrime said:
OE Creations Replicas PR197  20x9
Nitto RG 275/60/20
GM 2" Lift
If I may ask, where did you get your wheels from? Any spacers needed to clear the calipers, etc?  Thanks
Absolutely. No spacers needed.
I bought them directly through Discount Tire who is a dealer for Wheel Pros. Once I found the wheels I wanted through website below I called discount and placed the order.
https://www.wheelpros.com/wheels/oe-creations/
Anyone go from the Nitto Ridge Grapplers to the Terra Grappler G2 and were overall happy with the change? This is for stock size 275/60/20 in p rated XL.
Vision Rocker, 22x10 (-19)
Nitto Ridge Grappler, 285/55/22
Bracket mod w/ major trimmed splash guards, minor rub
Edited by EZ Money
add photo
Excuse the dirty truck. Stock height with CK160s and 285/45/22 tires.
I have the same CK160s wheels but did not fit my AT4 due to the calipers.  Did you puts spacers?  What size?  Do you have any more pics showing the stance or how much the wheels stick out past the fenders.
Edited by cansled
6 in zone lift kit,
20x12 xtream mudder rims,
35x12.5R20LT Nitto Ridge Grapplers,
-44 offset
No spacers needed
There was a bit of plastic and metal trimming involved, but nothing to crazy
Edited by Mrgolde
On 1/11/2021 at 7:30 PM, rico750sxi said:
Guys, I need assistance and opinions please regarding my setup I just purchased and test fit. The wheels are 20x9, 0 offset Moto Metal MO970 with 106.25mm hub bore. I purchased 3/8” spacers as suggested by Custom Offsets for caliper clearance. The Bora spacers are not hubcentric high concerns me, they fit the stock hub tightly but the wheels only mount lug centric now. That is my first concern and my second is the stud engagement with the spacer installed. I only get about 5.5 to 6 turns on the lug nut before seated (not torqued). I have some crappy 6mm spacers that I test fit and these gave me much better engagement and I could get 8 turns of the lug before seated. CustomOffsets said I was good to go when I called them as they said I had the right spacers and 6 turns of the lug was acceptable.
Am I okay running the wheels lug centric?  Am I okay with 6 turns of the lug nut on the stud? I’ve found 6mm spacers by ReadyLift that they state go from factory hub bore to 106mm hub bore which I am thinking about getting. Should I go that route? What are others doing, I haven’t found too much info except for info on bigger spacers. Thanks
https://www.readylift.com/6mm-wheel-spacers-gm-1500-2019-2021.html
Did you ever get a response on this? I'm looking at a set of wheels that will require 8mm or a 3/8" spacer and I'm concerned about the threads left as well. I plan on having Bora make a custom set of hub and wheel centric spacers that match the wheel bore.
Edited by dirtfan21
    • I have a hard time seeing oil from 'below' the rings 'pooling' in the cylinder. For an amount great enough to pool getting past the rings I would expect to see that same amount contributing to other noticeable symptoms, low compression, blow by, etc. You could try investigating for a stuck, gummed or carboned up ring, maybe an oil with different detergent strategy. Some other shade tree solutions like adding a detergent (or mystery oil) to the chamber and letting it sit, I've also heard of a heavy use of 'engine braking' to load the rings differently.   I would first be looking at oil entering from 'above' via a head issue, or intake/PCV issue. I suspect that the oil is entering cylinder 8 combustion chamber at all times but is getting burned off during each combustion event preventing a 'pool' from forming and lessening visible oil burning smoke. This leads back to valve stems or PCV system as the only route for oil to enter the chamber from. I would expect a PCV issue to not be isolated to cylinder 8 though.   Other considerations, how long does it take the pool to form? Could you look for the oil trail via the borescope? (Run the truck, shut the engine off, as quickly as practical, pull the plug and insert the scope and record to see how long and hopefully where from.)
    • National Average back up to $4.04 for gasoline and $5.35 for diesel.   https://gasprices.aaa.com
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
