2019 Silverado RST 5.3L. General grabber A/Tx 275/70r18. Full throttle +0 offset. 6mm spacers in front. Stock suspension.  Slight rub and full lock turning left in reverse.
On 9/8/2021 at 6:39 PM, Freeagnt54 said:
Icon Compression 17”x8.5” 0 offset
Toyo open country at3 275/75r17 (34”x11.5”)
Stock height? Any rubbing or trimming?
For those running Nittos, how does the actual mounted inflated height compare to the advertised inflated height?
275/70/18 bridgestone revo at3
3.0 RST duramax with 3.5" RC lift/ level
Stock 18" rims
Edited by SC4R3C120W
Picked these up on FB Marketplace brand new with center caps still in bags for $775 shipped. I love them over the stock silver 18’s
Part:84641199
Toyo AT3’s 265/65/18
Bilstein 5100 1” lift in front.
Edited by Mike Borowski
Stock 18" rims
Nice.  Hope you got new upper control arms for it.  We got a 2020 gas GMC Elevation here that has a 2 inch level.  Stock UCA ball joint failed, and hard.  Took out the CV, the wheel, ABS sensor too.
Correct.... New upper control arms and mine being a diesel, they recommend the strut spacer instead of the coil overs because of the heavier engine. Plus the 2.5" block with new V2 shocks. Rides just the same as factory. Was surprised the tires didn't ride more stiff or make any road noise. I was looking at 34's, but since I commute 120 miles a day, i wanted something lighter weight to try and keep mileage. These Bridgestone's were one of the lightest 33's while still having a little all-terrain patterned tread/look. They are each 15lbs heavier then my stock 265/65/18 Michelin LTX's, adding 60lbs more or rotating mass. I also got the RC speedometer calibrator to keep DIC correct
2020 Sierra AT4, 5.3L
275/60R20 Mickey Thompson Baja Boss AT
20x9 Fuel Rogue +1 offset, Gloss Black w/ Machined DDT face
1.75” ReadyLIFT Leveling Kit with UCAs
27 minutes ago, bluemonstercali said:
Truck looks amazing!!!! What tire size?
The wheels are Vossen HF 6-4 20x9.5 @ +15 offset. The tires are Falken Wildpeaks AT3W 275/60 R20s. No rub at stock height. This setup was on my old truck (21 Elevation). I just swapped them out!
On 3/28/2022 at 9:28 PM, Mattuz93 said:
3.5” Rough Country lift
295/65/20 ridge grapplers
Truck looks great great, very similar setup to what I would like to do. Did you have to run any spacers or make any mods to eliminate rubbing?
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
