At what mileage did you all have pads/shoes replaced on 2015 silverado 1500? Had the brake fluid flushed, but curious about how long pads/shoes lasted.
81k on a 2014, pads and rotors still have plenty of life.  Did a brake fluid flush around 70k and I had to tighten up the parking brake once.
It's the ferro-nitric compounds that allow the brakes to last for a long time.
8 hours ago, CamGTP said:
Have 100k miles and still rocking the factory brakes here lol.
Same here, 106k and I swear the pads aren’t even half worn!
72K on all pads/rotors on my '16, all rotors warped.  However, I didn't buy the truck until 72k, so I'm guessing the PO used the brakes often.  I've also seen threads here of guys needing pads by 40k.  Brake longevity comes down to driving style for the most part; the more times you touch the brake pedal, the faster they wear.  I replaced the front pads with Raybestos semi-ceramic; they stop awesome and produce almost no dust, but do make a squeal when cold.
Edited by dukedkt442
2017 sierrra. 63k
Pads are probably half or less on the front. Rotors are gone and warped. Rears? Fluid is down a bit in the master. Haven’t flushed her yet.
Looking for replacements....Chevy brake kit is too much.
Any opinions on the best stuff out there?
Factory replacement stuff or slotted typed upgrade?
Powerstop makes a nice kit for these trucks with good rotors and pads. Haven't had a problem them in the past.
Otherwise I really like the Ultra Premium coated rotors from Napa and the adapative one pads. I'd check those out for sure. If there isn't a rebate available you can still see if there is a discount when ordering online and picking up in store. Can save 10% sometimes.
50K on a 2015.  The pads are fine, rear rotors are fine, front rotors have a very little pulsation in them.  Will probably replace them soon.
These FNC rotors are actually really good and they don't show surface rust either.
Almost 75k miles, 2017 Sierra 1500 4x4. Pads and rotors still have lots of life left. Might go 140-150k. Never had brakes go near this long on any vehicle I've owned, not even close & I try to be easy on brakes. Truck still stops real fast when I want it to. When it comes time to replace, I'll just put the factory stuff on again. Why mess with a good thing?
Edited by Nanotech Environmental
34,000 miles and they look new - it depends on the way you drive, if it's all highway they're going to last 100,000 plus.
typically brakes on these trucks last 75K ish some get more . you will get less depending on braking habits, towing, extra weight etc
as a tech i would recommend doing the brake fluid 45k miles/ every 3 years unless you are doing heavy towing and things of such then recommend to do it sooner just as other fluids due to the over working of the system.
I read all of these and am amazed. I have a 2015 Sierra 1500 Denali and earlier this summer I had to replace everything, pads and rotors front and rear at 42k miles.
So, I live in Syracuse, but work from home sometimes travel the Thruway to see customers. The front outside pads were real thin and the back pads were to the rotor. The back of the rotors was rusted craters.
The rear brakes looked OK, on the outside, but the rear inside pads were getting pretty thin and the rotors were rusted bad.
This is my vehicle that stays outside, but I never let it stay dirty and stop at the touchless carwash after any real salty travels.
I NEVER leave my truck dirty or salty.
One thing I wonder about is the factory 22" rims -they definitely leave the calipers very exposed?
Funny thing was the truck had been NYS inspected last September and they didn't say that I was close. Never heard the wear indicators, The only reason I took a closer look was because I had just started feeling a very slight pulse and heard a light growl.
I totally love this truck and was just surprised by the brake wear.
Edited by Glava2876
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
