42 minutes ago, FiatDale said:
I’ll do a write up, but it’s tricky to not screw up the headliner by putting a crease in it. Also, I use air tools which made things 10x easier because some of the 10mm are hard to get to with the headliner in your way.
You think the dealer would do it if I provide them the parts? Don't want to mess anything up and if they do, it's on the dealer! ?
4 hours ago, FiatDale said:
And I’m the pompous king? Here trying to help
He actually called you a pompous ass, but I like The Pompous King much better!!!
And it was a nice write up, we need more on the site, especially with pictures.
You think the dealer would do it if I provide them the parts? Don't want to mess anything up and if they do, it's on the dealer! [emoji28]
If they do, they’d charge it hourly at their shop rate of ~$95/hr. They would most likely do it all on book time, so if I had to guess they’d figure 4-5 hours. For that much in labor - you’ll be able to do it easily.
Dale,
Thanks for the write up and the correction on the shopping list.
You've done this group a big service.
What had confused me was the need for a camera/light and then the spoiler.
So, if I hear you correctly, the spoiler has the light, camera and then cable ... but you still need the extender cable.
My concern, as others have voiced, is our ability or lack there of to remove and reinstall the headliner without damaging it.
Are there instructions on line some place or did you just work your way through it?
Thanks again,
Steve
You're real lucky if the local GM dealership only charges $95 and hour for labor.
My local shop gets $150.
At that rate, this is going to be a DIY job or not at all.
Steve
Some background, I do auto body by trade at a GM dealer here in Houston. I’m very well versed on these things and their assembly so you’ll have to forgive me when I say it’s easy, because I do this stuff everyday. By most DIY standards this is an easy job, it just may take you half a day so you’re careful. I will do a write up with pics soon.
Thanks again Dale .....
I  just watched this video from A1 Auto on YouTube and it seams like a REAL PITA job.
Hints and or tricks would be GREATLY appreciated.
Steve
Regardless of price, $95 or $150 - no dealer would do this. I have never met a dealer that would take parts you bought and put them in your vehicle.   *if* you could even get them to agree to do the work, you would most certainly be required to buy the parts from them too....    but as has been mentioned tons of times in this forum - dealers do not want to put extra stuff in your vehicle... to much hassle on their end. Either get it at purchase time, or do the work yourself...  dealer is out of the picture at that point.
I would trust myself to do it over the dealer. They made a royal mess of my headliner.
Wear disposable gloves to keep everything clean...from what I’ve experienced and seen happen to others, the techs probably won’t!
Thank you for all the information Dale! Very helpful. If others can’t figure it out from here, they shouldn’t be attempting it in the first place.
Hi, I did install a mirror and camera in my 2014 SRX, parts taken from a wrecked AX4 model 2019, the camera P/N is 84510303 but it doesn't show individually, according to GM it's part of the complete spoiler assembly P/N 84517274 which cost a lot. I was lucky to find a AX4 at a local salvage auto parts shop.
The Mirror P/N is 13530414 and it is the second generation, it is drop in replacement to the existing and uses the same plug configuration, didn't had to modify anything, took five minutes to install
Fitting the camera was a nightmare, I made the setup very similar to the AX4, camera is fitted into the rear spoiler, so I had to remove my SRX spoiler and made a small cutting and glued the camera!
I used 4.5 meters RG316 Cable with male SMA connectors from both ends, had to replace the camera and mirror Farka connectors and used Female SMA connectors, the reason that I couldn't arrange Farka or SMB locally and didn't want to order it and wait...
I have checked the original cable and it is indeed 50 Ohm, the camera is receiving DC power over the same coaxial cable which is used by the camera to sends the video to the mirror perhaps in the form of high speed data, similar to a GPS antenna concept, video is crystal clear, no lag, has a superior night vision capability, no flickering, noise or vibration...it is superior by all means.
I was worried only about adjusting the camera horizontally, the mirror has features like adjust tilting, zooming as well as adjusting brightness level and it is bright enough in day time at the lowest brightness level.
Setup is straight forward, did not require to do any sort of programming, took about 3 hours to furnish the cable, install the camera on the spoiler and drop the cable, it works!
Best of luck to all
Hazem,
Was dropping the entire headliner a must?
Did you have to remove the seats?
I looked at an A1 You Tube video and it looked like a nightmare.
Some of you guys are a lot more courageous than I.
This is a brand new truck to me and I'm worried about damaging the headliner.
Steve
Edited by Yoda2
spell check changed word
No Steve, you don't need to remove the headliner, pulling the coax above the headliner is quite simple but not easy for first timers, sorry didn't take photos throughout the installation process.
If you look above the mirror you'll see a gap above the headliner, this is the coax entry point, open any of the doors, remove the top of the black door seal you'll access the the gap above the headliner as well, so the pathway for the coax to the camera can be made either from the driver or the passenger side all the way to the camera, there are pillars on the way which you may need to carefully loosen or unclip in order to pass the coax, off course I'd wear clean  gloves for not getting the headliner dirty, also I know that there is airbag behind each pillar so I'd be very careful, Depending on the type of vehicle you have, if there is a rear spoiler you'll need to pass the coax through the rubber harness duct to pass the cable to the camera.
A Car electrician or those who install A/V equipment can make it for you in less than an hour,.
I hope you'll find this helpful
Hazem
Edited by hazem96
I'm waiting for this one from Gentex since two years, never came across a car that has it, hope it will be available commercially soon, its a rear view which also split the sides to show blind spots, something from the future.....
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 719 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
