i’m looking for exhaust recommendations  for my 17 Silverado.  I like a deep rumble, but not noisy/drone in the cab.  Im also looking for something that will last, not rot away.
What about single vs dual?
I have a dynomax cat-back with the ultraflo muffler I think. To me it sounds good and it's not noisy in the cab at all. At warm hot idle to be honest you can't really hear if there is a lot of background noise. 550rpm won't really make it rumble lol. Driving it under load is where you do.
I went one step further and painted my exhaust before install because even though it's stainless, it's the cheaper stainless that will still surface rust.
What's your budget?
I have the Borla S type catback system. Duals straight out the back. It sounds real good. Not too loud. But loud enough. At hwy speed it's not loud at all in the cab. Under load she growls though.
Lifetime warranty. All stainless steel. Around $929
It's all a matter of opinion on what sound you like.
There are lots of quality systems out there. Corsa was second on my list.
https://www.ebay.com/itm/324050550255
Not to mention it looks badass
i test drove a 2020 5.3l with GM's performance exhaust on it. they told me it was equivalent and made by borla to thier middle setup - touring i think. Nice exterior idle sound, nice sound accelerating but just cruising wasnt any louder than stock - i got out on the interstate with it worried the v4 mode would fudge with things but no drone no weird noises just quietness. stomp on it she growled nicely.
I plan to get the same dual out on my 18 when funds allow.
Borla or Corsa for longevity and quality. Borla for a sportier sound, corsa for the rumbly growl. I have the GMPP Borla. it's supposed to be touring but it definitely is louder than the Borla touring (non-GMPP). Has flapper so no chop in V4. I should have gotten the Corsa ahahaah.
Like others have said, it depends on your budget. If you want to do something very affordably, just have a good muffler shop cut out the stock muffler and put something less restrictive in. I had them remove the stock muffler and flapper and install a Flowmaster 50 series Delta flow. It has a much better sound than stock but doesn't get your attention at all or ever get obnoxious. Can hardly tell it's not factory when you're cruising. Most guys that change exhaust want something a lot louder than this but it is exactly what I was looking for. Find a good exhaust shop that can advise you on how to get the result you are looking for.
I went with the Borla ATAK cat-back exhaust for my truck (#140797BC). My dad has a Corsa exhaust on his truck and I don't really like Corsa's sound so that's why I went with Borla instead. I also chose to do single side exit, dual tips, because I don't like how the Chevy trucks don't scallop their bumpers for dual exhaust out the rear - just looks funky to me sitting so far below the rear bumper. Also a lot of the older RST/Premiere models in the Tahoes have this same side exit dual pipe look and that's what drew me to this look. Glad they changed it up on the T1's even though I think they're fugly as hell.
Highly recommend this exhaust even though it's on the louder end of the spectrum for most people. It will piss off the neighbors if you cold start it at 5am but the idle is music to my ears. Has a great harmonic. It really wakes up when I step on the gas. 80mph cruise control it barely purrs but you can feel it a little in the floor boards. It's nice. 60-65mph and under cruise control, can't hear it can't feel it. No cabin drone. My AFM is disabled with a Range device so no flapper chopper sound. Ugh, is work over yet so I can go waste fuel mileage???
On 4/26/2020 at 8:59 PM, dieselfan1 said:
What's your budget?
Agree with everything that Diesel said.....the S-Type was perfect for me.
This is what I am doing, except going with a 40 series.
I am considering going with the Borla ATAK system as well. How does it sound when the engine cuts back to 4 cylinders?
i wish they had a side exit crew cab standard box option. I suppose i could always just add in a spacer piece.
I have no idea since I'm using a Range AFM device to disable the cylinder deactivation. I have heard, though, that it sounds like an angry helicopter following you when it drops to 4 cylinders.
OP - First think you need to know is: Are you keeping cylinder deactivation or not?
If you are keeping it then be ready for the helicopter chop if you go with a system that eliminates the valve.
If you will turn it off and never go back then any catback will work, no chopper noise.
I have the Flowmaster FlowFX dual out, single in and i love it.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
