After much research, Shell Rotella Gas Truck motor oil and Wix/Wix XP oil filters (same as Napa Gold/Napa Platinum) currently used here.
[Formerly used Pennzoil conventional, Pennzoil Gold, Pennzoil Platinum, and Quaker State Ultimate Durability with AC Delco filters.  Quit using the ACD oil filters when they switched to the cheap "E-core" ones with plastic cages and cardboard end caps inside made for easier recycling over quality filtering (the ones that end with an "E".)]
5 hours ago, Fsu11 said:
I know this is about what oil, but since it goes hand in hand what filters do you guys recommend? I have a feeling its equally important.
Wix XP
I wonder how many dumbass threads like this one are posted on this site? What oil? What trans fluid? What tires? What filter? No wonder all the good members, with good content, hauled ass from here...
  • Like 3
Too lazy to look around the site for answers. Younger crowd I bet.
Purolator One or BOSS is my first choice. AMSOIL Ea second and WIX GOLD when I can't find or get one of the first two.
It really hard to get at the truth sometimes and marketing likes to make a game of things. But you can 'backdoor' the information by having included in your UOA's the cleanliness test ISO 4406 and ask that they include the raw data. Blackstone does this. Filters job is to filter. Cleanest oil wins. Remember, apples to apples. Same oil, same OCI ane so on.
There is what they say it will do and then there is what it does. And of course there is 'good enough'.
Not everyone realizes the search function works like a charm but not everyone needs an unnecessary berating either.
I was wondering which category he sees himself in?
feel free to post some good information or do some truck builds show us your skills or products. i'm way too busy with work to buld a truck. all the old members leased their trucks probably driving ugly T1's now or Ram trucks.
i am disappointed in the search function, its not that good, even at finding old post you know exhist on here.  maybe  you can make a video on how to use it correctly  'cause i aint got no skills with it
Edited by flyingfool
So what is your contribution? ?
Personally I found searching google with “k2xx” works very well for specific threads for our trucks on this site.
Maybe it should be proposed to sticky a thread about oil, as it drove people insane on the forum for my car (especially since they found a correlation with excessive cam wear with oil used on one engine).6d9e8a88537526d1d2168219f839dd67.jpg
They have a dedicated section for fuels and lubricants.
Some stickied threads include “Amsoil only” and a Blackstone thread where it has been active since 06 with users posting their results.
Then maybe there could be one giant thread these newbies can scroll through ahead of time before asking more specific questions.
On 7/11/2020 at 8:53 AM, newdude said:
Shell Rotella Gas Truck 0w20 now but I was running Pennzoil Platinum 0w20 on my first two oil changes, and ran that in my 2015 HD and the Euro L for my Colorado Diesel.
Good stuff and Advanced Auto is clearing out their inventory, $2.49 a quart :)
Its the weirdest thing!  I went to Walmart to get 5 quart jugs last month and this month, and they don't stock it anymore.  I don't get it.  I might have to go back to Pennzoil Platinum...
Edited by newdude
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
