2 hours ago, SWBuckeye said:
So, anyone happen to know if the wiring harness is present in the door for this option?
I've not taken the door apart yet but thought I'd ask to see if anyone knew.
I added painted handles yesterday to my 2020 LTZ that has keyless buttons on the front only.  The wiring harness is not present in the rear doors, was hoping it would be.  I added rear handles with buttons anyways though, I prefer the look of all 4.
Edited by pewterliftedz
NICE!!!!  Looks so much better.
Did you have to take the door pad off? Or can you remove it w/out doing that? Pls, do share.
Were the tow mirrors factory or did you add those on?  Did you replace the chrome window trim or wrap?
Edited by SWBuckeye
2 hours ago, amxguy1970 said:
I have seen this complaint a few times and don't understand it, and I have first hand experience as my Fiance's Rav4 does the same thing where only the front doors unlock the vehicle with the proximity key. All we have to do is reach out a few feet to grab the front door handle to unlock the entire vehicle, not a big deal. As vehicles do more things people get entitled and there could easily be other reasons for it like reducing accidental activation of the locks. For example it eliminates two doors that can be accidentally unlocked by leaning or rubbing against it. I know with the Rav4 if I have the key in my pocked while washing the car when cleaning the handles the doors can lock/unlock. My brothers Altima has the unlock only on the front doors and he just touches the front door then puts my nephew in the back, easy peasy.
Tyler
There maybe a few reasons for the complaint/criticism.....(not trying to be or sound offensive here?!)....but driver age, physical limitations, extent of use as well as how the truck is used, let alone the fact it is a $60K+ truck and a top of line trim package. When the truck is a 2nd office and you spend a lot of time on the road, it becomes a convenience issue that you learn to appreciate as you get older.....at least that's how I look at it.
my 2020 LT  has buttons on both front and back doors
The other thing that pisses me off about gm when they remove stuff for new model year, typically the prices go up a little bit anyway.
For the new model year traverse they are getting rid of the more advanced awd system to a cheaper one that isn't as good but they aren't charging less. Its a bad philosophy that GM seems to have these days for all their stuff.
Yup, kinda like how the T1s have single speed transfer case now if you don't pay extra for Z71
So the 2500's get the back buttons ? Any pics ?
thumbnail?appId=YMailNorrin
kinda strange why they wouldnt do same for both 1500/2500/3500
i had to remove all 4 door panels.   The fronts you need to remove them to unplug the button wires, on the rear I didn't need to since I didn't have buttons originally, but I wanted to see if the wires were still there.  If you do not have keyless entry buttons the door handles are super easy with a simple youtube search.
I added the tow mirrors last week, they are factory power folding and have blind spot.  I was able to find them on ebay.  Chrome trim was wrapped with gloss black vinyl.
4 hours ago, Wayne Black said:
Oh God! It's so HARD to unlock the rear doors by punching the front door lock button twice!
How will I get by?
1st world problem.
Not so much a First World Problem as it is a Second Year Problem. Few of us would even care to lift a finger to complain about the (shortsighted? Misguided? Stupid?) decision to remove the rear buttons from the Chevy lineup of the GM brands, if they had not given four buttons to us to begin with. It’s perfectly rational to air one’s grievances in such a scenario.
And as one who uses the rear button almost more than my front button on my 2019 RST, I sit in the camp of grievances.
Edited by econometrics
You can configure the front buttons to open all 4 doors with one touch; problem solved.
Edited by gf2020
Or, for once in their life, GM could decide not to cheap out and just give everybody four buttons like they did for 2019.
It's also entirely possible that GM was having issues replacing faulty rear buttons and just decided they weren't needed and you could configure the front button to unlock all the doors.
When I was a Senior in High School my daily driver was a '57 Chevy and I know this sounds crazy, but you had to actually stick the key into the door and turn it 90 degrees to unlock your car!
Times were tough back then!
A friend had a '57 four door hardtop and to unlock the back door you had to reach around in the open front door and pull the button up!
By the end of the day, you were totally exhausted.
Sarcasm.
  • Haha 1
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
