On 9/19/2020 at 12:36 PM, 2018GMC said:
I’m not excited to replace mine when the time comes.
I will prob go for a Walmart / sams AGM. Maybe north star if I feel like spending that much.
Has optima improved since the mid 2000’s? I know when they moved production out of the USA people complained the batteries weren’t as good and didn’t last as long.
What model and brand of replacement battery did you install?
Any odd behavior with dying battery or it just wouldn’t start?
I replaced my Toyota 4R with a Red Optimal in 2012 and my 2003 Corvette with a Red Optima and have had 0 problems.  Since I dont drive the vette a lot, the old batts would drain down a lot,.  Both have been great.
Edited by AE1M
Add more info
30 miles from home on our first date night in months after having our firstborn, factory battery decided it didn't want my wife and I to get home. No warning, no sluggish starts or previous jumps. Went from no issues to completely dead. Fortunately my father-in-law was free and drove me to Autozone where I picked up an Odyssey 48-720T (AGM). Went with an Odyssey in my 1997 Wrangler and had zero issues in 6 years with it, figured I'd go with something I can trust. Got 4 years out of the factory battery. Was a pain to do it in the dark by the time we waited for him to pick us up, run me to Autozone, grab my tools, then get back to the truck...but it wasn't crazy hard to do. Helps I'm 6'4" though and could reach everything, would have had to stand on the tire otherwise. I've heard people say they put all the bars in the way to prevent theft, are stolen batteries still a thing?!?
So, I used whatever Napa had.  I paid $147 out the door for an AGM.  Keep in mind I get a good guy discount since I used to work for a Cadillac dealer, so we used them a lot.  As far as Optima batteries go, I have heard the same complaints you are hearing.  I didn’t want to spend the ridiculous money for a Chinese battery.  I was having AC issues with my old battery.  My driver’s side wasn’t cooling as well as my passenger side.  I had an active body code for low voltage to the HVAV system, so after about 2 years of that battery, I felt it was time to replace it.  Slapped the new one in, cleared the body codes, and I’m back cool again.  My buddy at Cadillac swears up and down that I didn’t have to remove the coolant tank, but I did it anyway.  It made the job easier.
Thanks for the detailed reply.
Crazy what issues can creep up with a weak battery on these trucks.
Changed my  battery last night at Advanced and my power steering went out. Had to get a tow to the dealer, little frustrating.
I've never had much luck with factory batteries, not sue why. I've had them last 2, 3, and 4 years. all the replacements from sams club or advance auto have lasted a minimum of 7 years. The one I have in my beater is from farm and fleet and is 9 years old.
Did you find the cause?  Hard to imagine a batt change would cause that
On 9/19/2020 at 12:05 PM, Rossum Possum said:
For those DIYers...I know join the club of those who have replaced the old flooded cell battery.  I also believe the engineers at GM to be sadistic.  I’ve never had to remove so much crap just to be able to remove a battery, for Fox Creek...On the bright side, I did spring for an AGM, and it is smaller in size :)
Do you lose any settings in the truck after disconnecting battery?  Radio stations, memories, etc...  Window sync etc?
I did this today and installed an H7 Diehard AGM from Advanced, about $200.  I hunt in way northern NH and need a reliable batt when I need to start in really cold temps in a field in the woods!  The best video I found was here for the job.  My only difference was to remove the bracket center support instead of fighting with it.  The hardest part was removing the back bolt holding down the coolant reservoir.   It looked like too much to fight with a 50lb battery, used a bungie cord to hold it out of the way to remove and install. Total time was about 40mins including cleaning the tray etc...  No settings at all were lost, compass came on with the CAL message but it cleared itself after about 5 mins of driving.  Waiting for the temperature display to catch up, started with 32 deg when it was about 70 out.  The old batt might still be enough to start the truck, so I may mount it in the tray on the drivers side and just charge it occasionally to jump start myself.  Need to see what accessory I need, the existing empty tray doesn't have provision for the hold down clamp or I may just strap it there.
Turns out the kid at Advanced blew a fuse putting the battery in, $345 later I’m back on the road .
I did not.  The only thing that had to reset was the external temperature.  It showed 32 at first, but then it caught up.
There is a design issue on these vehicles with the amount of stress the negative battery cable places on the post. I got 4 years out of the original and replaced with a AGM just over 1 year ago. Again same negative battery post failure. The bending moment on the post induced by the negative cable fatigue cracks the post inside the battery. The plastic housing holds everything together and you will pull your hair out when temps and moisture cause the air gap in the cracked post to create resistance build up losing voltage and amp draw. Both times mine exhibited starting issues given the amount of amps you need to turn the motor over. Easy way to tell if your post has failed internally is to put a 10mm socket and wrench on the nut of the negative cable and tighten the nut only placing a small amount of torque on the post while someone is trying to start the engine. The post will generally fail on the right side and propagate toward the driver side given the bending moment of the unsupported cable length. There is a hole in the trough above the cable that I used to use a zip tie to support the cable and reduce the stress on the post. You guys may want to do that first chance you get. Hope this helps those experiencing electrical issues that tend to come and go until it finally cracks far enough to put you dead in the water. Regards!
Also the battery can be removed without taking the coolant tank out. Remove the fender brace and the lower support that mounts to the battery tray. Then rotate the front of the battery toward the driver side and lift it out. Pretty straight forward. The first time I swapped batteries I removed the tank. Then tried it this way the 2nd time without much issue. However, YMMV.
I bought my battery at Advanced and they told me it comes up on their computer that they are not allowed to replace them. Guy told me it requires "professional" to install it on these trucks. Lol
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
