3 hours ago, bshort said:
Running a fleet of Fords now....problem free since 2015.  I'll probably lose an engine now... ?
We got 2 ford E350 box trucks in our fleet, been damn good since 2015 as well. Heck we just did it's first spark plug change at 262,000 miles on one of them. The tech said the gap was .110 but it still ran okay LOL. It was only more than double the spec but hey it's alright......
Maybe I just got a Monday morning or Friday evening truck... no offense to anyone here. Im sure there are trucks with zero issues and will run for 300k miles
Sent from my Pixel 3 XL using Tapatalk
There's no need for you to justify yourself, dude. My Sierra has been problem free, but I can remember having my '14 Silverado that developed the notorious driveline vibration issues that just sucked. I wanted to love the truck so much, but I just couldn't. Every time I drove the thing I just hated the experience. Luckily, my dealer made me a good deal and I decided to give GM another try. My '16 Silverado was also problem free and I enjoyed every mile of ownership. I seriously considered going back to Ford though, and if the dealer hadn't done me right, I probably would have. GM corporate was of very little help.
Like I said, enjoy your Ram.
On 10/29/2020 at 7:55 PM, Porterhouse said:
While this is a great forum and network I gave up on my silverado this week. After the roof leak and the transfer jingle I've decide to part ways 10 months and 4k miles later. Thanks to everyone on here. PS don't go drive a Ram limited when your mad at your silverado....
As the owner of a Big Horn, welcome to the dark side! You'll be back here though from time to time, like me, creeping around, just checking out what the competition is doing. ?
I'm in the same boat over my 2019 Cheyenne RST 4x4. I am looking to buy a new 2021 Ford Lobo 4x4.
I wish it would handle better on rough roads, I encounter a lot of that in Mexico.
Edited by Wiggums
Putting in aftermarket shocks is a lot cheaper than losing your shirt trading for a new truck.
Vye, Vye Uncle Rico, you will be missed.
Good luck catching on with an NFL team this year, show them the video of you throwing a football over that mountain again....
Buy what makes you happy, your money, your decision.
Good luck with the Ram.
I was at a Scout function with my soon-to-be Eagle Scout this past w/e.
Parked my son's truck next to a brand new Ram.  Man...those interiors...really something to be said about how much nicer they are than the GM's in my opinion.
I don't have an opinion on their durability or how quiet they are...but they do look nice.
Glad GM is updating the interiors on these trucks.  Not that ours are bad...but you put them side by side...wow.
As a non-brand loyal person, wish you the best.  I've owned all 3.  The reason I chose GM this round was because the cost vs features vs durability.  I feel Ford is the best reliability-wise but unfortunately, equally optioned out, cost ~10k more.  The Dodges I've run (with the exception of older diesels) have been constant money pits
Love it , and nice color too.   Lets see that interior!
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
