55 minutes ago, JohnH4260 said:
How does one delete or get rid of the flapper?
Any muffler shop can get rid of them and weld pipes back in their place, especially if you plan on removing or replacing the muffler. A good aftermarket catback system will also take care of the flappers. I'll say this - there's an incredible difference in the way these trucks drive with the flappers gone. I did the muffler delete and left the flappers and have since moved to the Corsa catback system. It's a different truck now.
10 hours ago, kodiakdenali said:
Very strange...2020 Denali, I only had 1 flapper.
now I have 0 ?
How did you get rid of it?
Installed a borla atak cat back.
You can lock them in the open position to get a bit more sound but that wont completely remove the restriction. To remove it without doing something like a cat back would requiring cutting that section of the pipe out and welding in a new piece.
Although if a cat back fits your budget there are many other benefits over just removing the flapper.
I had two on my 2020 6.2L Trail Boss LT.  I deleted the muffler and both flappers, it was too loud so I put one back and now it's perfect.
Does anyone else notice this noise when in 4 cyl or less than 8 cyl mode?  Wondering if it is due to the flapper or flappers.  Edit:  Not my truck, found this on another thread, but sounds just like mine.
Edited by Troger
2020 AT4 6.2. build date Nov 2019. It had 2 flappers before I installed the GMPE. No drone btw.
Sent from my Pixel 5 using Tapatalk
I have a 2021 Trail Boss 6.2 and I only had one flapper before the muffler. This is what I did to get rid of mine. I cut all the 3" out and replaced it with a 3.5" Vibrant 304ss muffler and 304ss tubing. I debated getting the Borla touring cat back but I had a hard time justifying the cost. Plus i wanted to keep the resonators.
Edited by Firehawk99
2020 tb custom 6.2 had 2 flappers did afe muffler delete left 1 flapper wound it so it’s always open
  • 2 years later...
They got an award for making something that chokes the engine and kills performance.   Wow.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
