  • 3 months later...
Did you guys use the same H11’s for the high beams or go with different ones like the 9005’s?
I used the h11 Fahren on both high and lows, so far no issues.
Thanks! I have them for just the low beams so I’ll add them for the high beams too! They’re bright as hell compared to the halogen bulbs
used seal light (made for halogen housing) on 2020 2500 and my new 2022 2500.......absolutely perfect, ive owned 2019 RST and 2021 GMC elevation with LEDs and these are better......sure it probably doesn't matter and any reputable brand works same.......i used same for high and low no issues with beam pattern or throwing codes......also replaced reverse lights as well......tail and turn signals i dont care about
the stock halogens are a joke for 60k truck ......no vehicle in this day and age should have them
cool thing is replacing them is easy......if you have stock LEDs in GM truck and they go out you have to replace whole assembly (another joke) though i guess they arent suppose too but still
Edited by Dunn
On 3/25/2021 at 5:14 AM, stephane lamoureux said:
Has anyone been able to do the LED swap on their Silverado without the truck computer going wing nut.  I am told it is a power issue since led takes less power then the old bulbs...
I has issues with mine when I got the cheap ****** from Amazon. LASFIT is the best for led swap built in resistors, no fault codes and they are BRIGHT AF. They are a little pricey but well worth it. Good luck
On 4/3/2021 at 8:54 AM, Sledguyry said:
I went with these for the high and low beams.
Fahren H11/H9/H8 LED Headlight Bulbs, 60W 10000 Lumens Super Bright LED Headlights Conversion Kit 6500K Cool White IP68 Waterproof, Pack of 2 https://www.amazon.com/dp/B07NPMV1H5/ref=cm_sw_r_cp_api_glt_fabc_2YD2RG7XK4YRBZVMZRB0?_encoding=UTF8&psc=1
And these for the backup lights.
Alla Lighting 912 921 LED Reverse Light Bulbs Extremely Super Bright 4014 30-SMD CANBUS 921 LED Bulbs RV T15 T10 906 W16W Back up, Cargo Lights Replacement, 6000K Xenon White https://www.amazon.com/dp/B072FHNZKW/ref=cm_sw_r_cp_api_glt_fabc_TRWF41QMYARNMZ38AC44?_encoding=UTF8&psc=1
So far no one has flashed me at night. Much better then the stock halogens. It was a pretty quick and easy install as well.
Thanks,   Did the headlights work as is or did you need additional canbus decoder?
Plug and play for me,nothing else needed.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
