On 3/25/2021 at 11:23 AM, Bob Ross said:
I have considered dropping the profiles. My radio takes too long to load. If you do this will the seats still adjust to each key? If my wife drives the truck she is much shorter so having the key settings is nice. But if it solves loading screen issues it may be worth it.
Memory seats/mirror settings are tied directly to the FOBs.
On 3/24/2021 at 5:17 PM, scott80109 said:
Same here. I have a '21 Canyon. If I turn it off for more than 10-15 minutes, the equalizer resets to all 0's. Had it about a month now, and I'm getting tired of it. Trying to make an appointment with the dealer to see if they can fix it.
I wish mine reset to zeros, mine sets the mid-range to 5 and the treble to 12 and the audio sounds terrible until I adjust, also the auto volume resets to off every time as well.
On 3/25/2021 at 6:21 PM, scott80109 said:
I had a couple of days where it retained the EQ settings, then today it lost them again. I started my truck up today, and everything was fine. While driving, I plugged my phone in via a USB cable, activating CarPlay. I made a quick stop where I shut my engine off, but left the phone plugged in. When I started the truck again, the EQ settings were lost, and the volume was at 0.
I now have a theory that the settings are being lost when I plug my iPhone into the USB port BEFORE starting the vehicle. Anyone else think this might be what they're seeing?
I have a 2021 custom and the equalizer resets randomly with no rhyme or reason. I have my moved my phone to the 12v power source with an adapter and it still resets to factory settings. It is insane and annoying.
I just bought a 21 silverado rst a couple weeks ago, my truck is doing the same thing, called the dealership a couple times and they dont know what im talking about. They are going to have a tech look at it on monday
14 hours ago, Dan James said:
I reset the audio and truck settings in the settings menu and haven’t had the issue since...
Did this seem to fix the problem, my new truck does the same thing and it pisses me off
I just bought a 21 silverado rst and have the same problem. Any one figure this out yet? Im having the dealership look at it on monday when they install the tonto cover and dark essentials package
Yes I am having this issue too with a 21 Silverado LT, no profile.  Sometimes it maintains volume and equalizer settings, sometimes it wipes them to zero (equalizer) and a much louder volume (maybe too loud even if I was still a teen....oh so long ago) level.  I haven't figured out why yet but am trying different combinations of leaving radio off/on, leaving phone unplugged (well know it's not this/Android Auto as I haven't plugged in in a few weeks) and Blue Tooth.  I unpaired my phone this morning and will see what happened, though other than "being paired" I haven't been using any sort of BT music/sound in a couple of weeks and don't think I've even gotten a phone call either.  But, seemed like something worth removing from the picture.  Very frustrating though.
I've had a 2021 Silverado Custom for just over a month. This happens almost every time I start the truck. It's very frustrating as I upgraded the factory speakers and it doesn't hold my equalizer settings that makes them sound best. Doesn't appear GM is going to help us on this either 😠
I've had my '21 Silverado 2500 LT for almost 2 months and it's done this from day 1. Volume resets to a "medium" level and my EQ resets to all zeros whenever it decides to. It doesn't matter whether I leave it on FM, XM, Bluetooth, or plug my phone in or not; It has a mind of its own. I haven't tried resetting the radio back to factor yet, so I'll have to give that a shot and see how that goes. Hopefully GM figures something out and pushes an update to fix it, I don't really want to have to take it into the dealership if I don't have to.
Figure I'd at least follow up since resetting my radio back to factory last Friday. The good news is that I haven't had any issues since I performed the reset. So almost a week problem free when it was happening pretty much daily. Reading the posts on this forum I'm starting to think it only effects trucks that do not have the memory function for setting drivers preferences based upon which key you are using. I've noticed it's really only people with lower trim levels that seem to have issues with the volume and EQ resetting. Hopefully this "fix" stays and others hopefully can do the same to resolve their problem.
2021 Elevation - happens often and it is annoying and frankly embarassing.  Hope some of those folks who said they would let us know after dealer visits reply.
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
