On 9/18/2021 at 5:17 PM, GJR1212 said:
I like my 3.0 GMC 4wd truck.  It gets great fuel mileage in normal rural driving.  It is averaging around 25 mpg.  It also tows my RV better than my old 5.3 Silverado or my 5.4 Expedition.   The 10 speed transmission is very smooth.   I have had one long start episode.   Unless you have to have a new SUV today, I would wait and get one next spring.   GM will eventually fix this problem, but right now they seem to be selling their gas trucks as fast as they can build them.   They do not seem to see the hiatus in 3.0 productions a serious problem- in my opinion.  My guess is the number of truck really seriously impacted with these long starts is a modest number.   Albeit, it is a big issues with those of us involved.   Discounts and Incentives do not seem to be what you would expect at a model year end either which is perhaps another reason to wait and get a 2022.
Thank you for the reply and advice! I sold my 2016 YukonXL, not in a hurry, but don’t know if I want to wait until 3.0l issue has been fixed. May end up getting 5.3l YukonXL AT4 instead.
On 9/18/2021 at 12:12 PM, Barrett10 said:
I would not but a 3.0 on any vehicle at this point.
Thank you for advice!
3 hours ago, MyFordsNeverBreak said:
It's happening to trucks and SUVs, anything with this engine, mostly 2021 models.
Thank you!
On 9/16/2021 at 7:44 AM, Gruggas said:
Hey just wanted to update people. I got the shim installed on the cam position sensor and just had the same reoccurring problem. Shim is not the fix.
Just an update... received my complete refund on Monday, down payment, payments, payed off my loan.  When I went to the dealer to sign all the papers, they now had the cab removed to reassess the fix that did not help.  The first time they removed the front end, motor etc to add the shim and the new reluctor wheel; but then the truck would not start at all--it would just turn over.  The GM engineer had them remove the cab to figure out what happened--so basically the whole truck has been tore apart--sure glad I am out of that rascal.
I traded mine in on a new Tundra, first GM truck I’ve ever owned out of many trucks, and the experience only lasted 4 months! Thank god the current times didn’t make it an expensive mistake buying a GM, got what I paid for it on trade. There is no fuel mileage so good that overcomes reliability and not knowing if my truck will start or what will F$&# up next, Never again!
Edited by ColoradoCub
That is a good looking Tundra, by far the most reliable truck on the market. I took my 21' AT4 to CarMax and they offered me more than I paid for it, so it was an easy decision to dump it right away. Hopefully GM gets this problem figured out, they have a winning combo with the 3.0 Duramax and the 10 speed trans. But for now, it's not my problem anymore!
Back from my 12 day trip and 2400 total miles. I used the delay start by pushing the button without foot on the brake and waiting a few seconds before starting. No long cranks/no starts on the trip. We'll see going forward.
It would be fitting that a cheap a$$ chip from China is the problem. First thing I do when ordering something online is check where it was manufactured. If from Coronaville, he11 no.
Still no word on a fix? I’m currently sitting in my truck waiting on a tow. When this first started happening it would always fire up on the second try. This is the second time in a row that it won’t start at all. Last time I unhooked the battery for a while and it worked after that. Gonna let GM mess with it this time.
Edited by WontStart
Painful when I think about all the work I put into it that I'd have to repeat and probably never get the money out of it.
Roll-N-Lock
Line-X
Luverne running boards
Tint
Wheel well liners
Advanced wheel locks
Smartliner mats
Anybody close to end of factory warranty and get any kind of extension or agreement for this problem?
Has anybody had any luck in the cranking with no start issue? I bought a 3.0 Duramax GMC Sierra 6 months ago and this has happened a dozen times. It always starts on the second try.
26 minutes ago, Dino76033 said:
Has anyone that does not disable the Auto Start/Stop feature ever had this happen at a stop?
I've read most of the post on this and I do not recall anyone having a long crank, no start from the auto start/stop.   The ones that do it most offend seem to get with the remote start as well as the dash button start.   If your foot is touching the gas or the floor mat is laying on the gas, you will get long crank, no start as well.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
