As of Wednesday, I was told my LT Trail Boss std bed Dmax was produced and is sitting in Laredo Tx awaiting rail transport to the distribution center in Dallas. From there it will head to my dealer. I have no idea how long that will take.
Let us know when it gets to your dealer.
On 3/10/2022 at 11:53 AM, BigBadSierra said:
Looks like they are showing up.
Man that looks so much better in those shots than the pictures my dealer showed me when selecting colors.  I’d have given it more consideration, if I’d seen it at first.
It showed up today.
Sorry for the multiple posts. Don't know how to condense them in 1 post. I pick it up Friday. It's getting a Roll N Lock A series and Toyo Open Country A/T3's 275/70R18 put on it before I pick it up hopefully.
  • Thanks 2
Sweet! Congratulations man! Whats your first impression of the interior?
They really improved the front end of the new trail boss.
What's your first impression of the interior, i have an LTZ on order....thanks!
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
