5 hours ago, Medic4552 said:
Its the carbonpro holding everything up. That why my AT4 hasn't been build. I was legit the 1st order at my dealership and multiple orders after me have been accepted and mine still hasn't. I personally feel like GMC shouldn't have made something a standard feature if it's in short supply. Im sure plenty of people would rather have their denali ultimate now without carbonpro rather than wait
I haven’t seen anyone with a carbon pro AT4 order get accepted yet. I’m sure there are other things holding up other trims but it’s definitely the carbon pro holding up standard AT4 orders.
Looks great! I ordered the same truck. Nice to see the reserve wheels looking so good. That's the best shot I've seen of them.
Yup haven't got my AT4 Carbon Pro 6.2 accepted yet. I ordered 1/27/22
Atleast 1 Denali Ultimate has been built. Theres 1 on the lot in Connecticut. Frost white with the 6.2. Only missing front and rear park assist.
My order was accepted Jan 29th , its built ,today the dealership sent me a update
Current event 4B00-bayed
Delivery Delayed
Must be stuck on a trian , somewhere between Mexico and western Canada
Denali  3.0 diesel  Summit white
On 3/24/2022 at 11:30 PM, Beastland said:
That thing looks amazing!
Thank you both!  I'm really happy with the wheels.  Without having the spy shots of the black "regular" Denali from back in October, I would have been hesitant to order a truck with wheels I've never seen but I'm really happy with how they look.  The sales team at the dealership all were looking at them and taking pictures as they hadn't seen them either being this was the first Denali they had come through.
My order was suppose to start the week of 4-4 at fort wayne now they are saying the fort wayne plant will shut down for that week and the next but my tpw still says 4-4 as of today. Man I hope they sneek it in before the shut down. Doubtful though. Code is still 3300
2022 denali ultimate 3.0l frost white
How do you know its scheduled for the Fort Wayne plant? mine also has a tpw of 4-4 but i don't know which plant..
Dealer looked it up for me a couple weeks ago when I first got my tpw. I guess they could change it but every denali ultimate that has been built so far has been from fort wayne.
The 3rd party supplier for carbonpro is right next to the plant in fort wayne
I chatted with Chevrolet and they said that my TPW has been moved back to 04/18 from 04/11. They said the facility it will be built at is Flint Michigan. Do you know if this is one of the facilities that will be shut down for 2 weeks? They couldnt tell me.
Just placed my order for a Elevation Crew Cab Standard Box 3.0L. Deposit made on 3/24/22 order was accepted today for production 3/30/22.
I was expecting to wait a lot longer than that. When I first walked in the dealer and told them what I want I was told 4-6 months.  Im thinking it's going to be sometime the end of May based on what I'm seeing here.
Now to start getting my 2013 2500 cleaned up and sold... Oh how I wont miss 9mpg daily driving
Hey guys, anybody having any luck placing orders on the Denali ultimate? I placed an order on March 7 and was told on the 17th that my order wasn't accepted as GM is no longer taking Denali ultimate orders.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
