Hey Everyone-
I have a 2022 AT4 (5700mi) and its it has a shudder/hesitation during steady and/or light throttle acceleration between 25 and 70 MPH.  Anyone else experiencing this or has and got it "fixed".  Reproduced it for a ride along with the dealer, but need to figure out a plan or approach to fix this.  They have mentioned maybe a fuel injector, maybe a new transmission....
Thoughts? Recommendations?
Also, what site does everyone use to search for TSB's?
Edited by OSXROB
What engine?
I have had this issue with my 2020 AT4 (5.3L) and dealer has not had any luck finding the issue as it's not throwing any codes.  They replaced the torque converter 6mos ago but it did very little.  It feels more like a misfire when under slight load.  I am looking at trying a different dealer to further diagnosis.
6.2.  But sounds like similar experiences. No codes here also.  My dealer didn’t think it was torque converters but hasn’t really offered much As to why not.  They also said fuel injector issue but would expect to see some sort code in that scenario.
I bought a 2022 Sierra 1500 AT4 last week and having similar issues.  A shudder or studder under light load and relatively low speeds.  It gave me a notification to have traction control and ESC serviced.  Went and spoke with service department at dealership this morning and they hadn't seen any similar complaints.  Taking it in next week for service to investigate.
Mine is going back to dealer this week.  I pulled this bulletin and shared with dealer and they are going to dig deeper to see if it is related to my issue.  They weren't sure but did say my vin shows that the crankshaft learning procedure may be necessary so I'm hoping it's a simple software update vs the "i don't know, it drives as it should" type response.  It's gotten to the point where I don't even want to drive it...pretty annoying since it started around 15k and now I'm pushing 34k miles.
https://gm-techlink.com/?p=15026
  • 5 weeks later...
I’ve had mine for 4 days. Same issue. I got a check engine light though. Going to dealer in 3 days.
We are at day 8 at the dealer and they are telling me it's tranny related and it will need to be pulled apart to determine the issue.  Really don't know what to think at this point...so much for thinking the 10spd was a solid option.
Edited by ajs800
Took it to the dealer today because it was throwing error messages about everything. Check engine light went off when I put gas in it today. I’m thinking it’s the tranny but it runs pretty rough at idle at a stoplight. Hope to hear something in the next day or so. Keep y’all posted.
Update- dealer said they found a bad fuel injector. Ordered part #12726901. Part is on backorder. I’ve been waiting a month now and still no ETA from dealer.
Update:  Dealer finally determine what was causing the shudder / misfire type feeling when maintaining  a constant speed.  They pulled the cover and filter and discovered shavings throughout the tranny most likely from a bearing.  Additionally, one of the internal pumps is way of spec in terms of free play so either the bearing it was from that particular pump or somewhere else within the transmission.  One year after initially taking it in we finally determined the problem.  It started around 15k miles and now at 34k.  Waiting on GM to give the approval to replace with new tranny vs rebuild.  I will probably be moving on to something else once repaired.
Edited by ajs800
I had that issue in my 2017 around 60k miles. I had the mechanic replace ALL the fluid with Amzoil. No more issues. Its might be worth a shot.
Well, after a new torque converter, new 10spd tranny, new motor mounts , shutter /misfire (almost like a tranny slipping feel with light throttle) still present. Not sure what else to do… dealer has no clue and agrees there’s something wrong. No codes and everything monitored seems within specs.
This is certainly not what we like to hear, ajs800.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 Sierra AT4. To do so, please send an email to [email protected] with ATTN: ajs800/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • Haha 1
  • Confused 1
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
