17 hours ago, customboss said:
As if you didn’t know that.
Had to keep the thread going, make sure it remains stirred. 😉
On a more serious note, one of these days I'll end up keeping a vehicle for the long haul. If I make it 100-150k that would be a first...boredom usually hits first. I've owned higher mileage vehicles, purchased or given to me and I generally prefer newer/nicer for my primary mode of transportation. But if I really like something I may end up keeping it.
0w20 in a diesel is still a little shocking to me. 5w30 in my first little diesel (GM 2.8) years back was also shocking, but those have held up over time. Can't say I'm not just a little skeptical of such thin oil in the 3.0 so I always like to hear perspective on it.
3.0 diesel was designed for 0w20 from ground up.
Edited by customboss
11 hours ago, Grumpy Bear said:
And exactly what grave danger will befall the 3.0 with an increase in HTHS viscosity? Give me ya' all's best horror story.
:lurk:
I want to hear TRUE SCIETIFICALLY VERIFIEABE experiences of 3.0 motors failing and traceable solely to higher HTHS viscosity.
I already gave scholarly articles that PROVE it WILL reduce wear. The trade is fuel economy...sometimes.
It was NOT designed for higher HTHS. You buy one and show us. Quit telling others what to do when you don’t have a risky dog in fight. You post what others tell you that support your bizzaro theories.
At 70 tomorrow. New or used and not collector cars. I’m usually good for 3 years with any daily driver. Something usually comes up. A kid needs a car or a good deal surfaces. Funny though the Odyssey will pass 3 years in February.
10 hours ago, PunchT37 said:
Should we continue?
Interesting, If this was the case, every engine would be sitting at the dealership because it wouldn't provide protection. It's not the oil people!  It's the poor quality materials that manufactures are using all to save $$$$$$.
I'm not just saying GM, every manufacture's engines that use 0w-20, 0w-16, and now 0w-8.
  • Thanks 1
So you have ZERO PROOF for  your whining ramblings that it is damaging to this motor. OMG what garbage. BTW, there is not such thing as "Designed for this HTHS". But even if it was, SAE 5W30 would not DAMAGE the motor. You are spouting half truths and drivel. And for very reason of physics demands, it will improve wear. You can't CANCEL STRIBECK. :wtf: do you think you are? God?
Anyone else interested it the relationship between wear and viscosity hit this link
https://www.machinerylubrication.com/Read/518/motor-oils
[quote from link]
The best protection against wear is probably a product that is a little thicker (such as SAE 10W-30 or 15W-40) and has more antiwear additives than the oils that support the warranty. The best oil for your vehicle depends on your driving habits, the age of your engine and the climate you drive in, but it is not necessarily the type of oil specified in the owner’s manual or stamped on the dipstick. [close quote}
0W20 isn't even available in the UK accord to FORD  and yet the 3.0 is. :crackup:Yea, ground up design.
Edited by Grumpy Bear
We are talking about 3.0 GM turbo diesel and it’s not available in UK. 0w20 is sold in UK and EU quite readily.
“ US-made GM 3.0L Duramax turbo diesel engine (such as the LM2 or LZ0 variants assembled in Flint, Michigan) is not available in new GM vehicles sold through official UK channels.”
God? Im just a Nasty Nasty man. Ask Stan. 😝
  • Haha 1
@Grumpy Bear having actually worked on teams that designed engines we absolutely DO compute and test for MOFT for said engine design. IN ALL CONDITIONS.
Its hard to be your age and be checked publicly but Im not Joshing’ ya.
:lurk:
This comment dives into what a youtube channel called DemonWorks who is a GM mechanic that works a lot on the 3.0 engine at his day job but also has owned numerous personal 3.0 trucks and he had done UOA with a variety of 0W-20 oil brands and then switched it up to a 5W-30 on his current truck and I believe he generated a couple of 5W-30 tests and so far there was certainly a statistical drop in wear metals. I think now he is trying a 0W-30 for the winter and so those UOA's are yet to be generated. One thing is for sure, it takes time to create UOA's with a daily driver and the odd long distance trip within that at times, there is no instant gratification "answer" like a person would desire as of course owners of the 3.0 intently watching his results want answers now so they can make a possible better oil choice now, not years from now and I can understand that. Collecting good quality long term data is not a five minute gratification process but that is a statement your more than well aware of !, its a statement I mention for others reading my post.
Exactly!
I heard a really smart person the other day say, "Some peoples whisper is louder than a shout because of WHO they are not because of WHAT they say. Still doesn't make a lie the truth".
This Revelation isn't new to anyone who has invested any time in Stribeck, Hersey, Sommerfeld.
    • Needs a manifold gauge hooked up and the pressures read.   If you don't have one, time to take it to a shop and have it diagnosed.
    • How rusty is the truck?     The transfer cases on these are an aluminum case.  If its anything like the rear diffs on the 2015-2022 Chevy Trax, those will corrode bad to the point it will push fluid through the housing via corrosion porosity or a crack from age/stress.    We have seen folks over tighten the drain and fill plugs on these transfer cases and crack them that way as well.    So I'd say its a 50/50 shot on re-sealing the case.  If all of the surfaces are good and its not badly corroded, they probably can re-seal it.  GM uses RTV to seal the case halves.   If they mention JB Weld, the issue is the case.  Be it a crack or corrosion.  JB Weld "might" hold if they clean EVERYTHING very well and drain the fluid out of the case and clean the crack and then seal it.
    • A while back, my truck (2018 GMC Sierra 1500 5.3) went in for an o2 sensor and routine service. The tech identified that my rear output seal on my transfer case was leaking, and recommended I have them replace it. At the time I didn't think anything of it, and had them do the repair. Less than a month later, I noticed that the recently repaired seal was leaking again. I called the shop that did the repair and they warrantied the repair and replaced the same seal again. A few months later, I noticed that once again the same seal leak had come back. It wasn't a great time to bring it in and I ended up just living with it for 6 months or so, noticing small (smaller than a baseball) size oil stains below the truck when it would sit for a while, as well as oil spray on the frame (to the point where it actually took the underbody coating off in that one spot). Finally got around to brining it in again, but this time I took it to a dealership service center since I am in a different part of the state for school. They identified the same output seal leaks and recommended they replace them. They also said there was no scoring on the inside of the transfer case, so it didn't need to be replaced. They chalked up the original repair failures to non oem seals and a job that wasn't done correctly. Now they called and said the seals are holding after driving/sitting for a while, but they found a very small leak in the middle, that they recommended they seal with some kind of silicone/jb weld (not sure what they are using). I haven't picked up the truck yet, but I have been reluctant about this whole repair process because I feel like they are just fixing the same thing that keeps coming back, and I am concerned there could be another root cause for the seal failing. Has anybody else experienced anything like this, or have any ideas on other things that could be the root cause?
    • I just started having AC issues with my 2012 Sierra. The symptom is blowing warm air on all vents.  Here is what I have checked so far. Compressor clutch appears to be engaging and cycling  I checked all fuses and relay, no issues. The only thing I have notices is the short line that comes from the firewall is very cold / frosted. This line is approximately 12 inches long. The coldness stops when it hits the first line connector. As far as AC compressor - At first start the clutch engages, runs continually, Short AC line frosts up. After idling for several minutes the AC line thaws out some but is still cool and the compressor clutch starts cycling on and off every 5 seconds.  Any suggestions on what to look at next would be appreciated.
    • Unless you are using a bypass filer system with a Beta of 1000 at 2 micron the commercial filters we have access to, even the very best of them, are poor at the 5 to 10 micron range the typical UOA test can 'see'. Point is there are some truly awful filters being sold A 45 micron Beta 75 filter is what Dyson used to call a screen door on a submarine. That leaves wear metals disconnected from filtration unless particulates are larger than the test can 'see' and yet captured by the filter...which is its job. If that is true then you have a major issue screaming at you.    The graph isn't mine. It belongs to GM and their study on this area. I looked up those studies and provided those SAE tech paper addresses multiple times. Machinery Lubrication displayed it and confirmed it. So if you have doubts about the study you'll have to take it up with GM Engineering. Just like you would have to take up a difference in opinion about the meaning a word with Webster or the length of on inch with the National Institute of Standards and Technology.      Most manuals have two schedules. "Normal Service" and "Severe Service". On it's face it tells you that oil in severe service is more highly stressed and doesn't "Last as Long". The item to bore in on is LAST...what does that mean?    It's the same question one asks about how long to toast bread. What are the inputs? Bread type? Wattage of the toaster? Distance from the elements? What is your preferred level of done?    So lets paint this with a broader brush. Oil is made up of the base and the additive package. The first is altered by heat and oxygen and later is sacrificial with a finite life subject to inputs toward that end. Resistance and supply.    It is the reason an OEM's OCI's are determined by 1.) the specifications of the recommended lubricant and 2.) risk management toward the bottom line. Those lubricants are also subject to cost effectiveness for the OEM.    There is a tendency for most people to believe that the OEM recommended oil rest on the top shelf and that anything other is lesser than. Truth is there are more oils on higher shelves than those on the lower shelf below the OEM's. They make that choice on COST TO THE OEM. Testing is incidental to the margin.    GM makes MONEY, the car/truck is a TOOL to leverage MONEY. Insert whatever car brand you like. Until you forking over a million plus COST not quality is the driver. Thus it is by DESIGN the recommended OCI's and oils fall well short of 'best practice protections'. Proof isn't hard to find. GM Ecotec I-4 2400 breather system and cold start PCM tuning has killed more motors and resulted in more litigation for those that used the 'recommended' practice than GM could bear. What was their response? SHORTEN THE OCI. TWICE.    I don't know how long to leave oil in an I don't know how the oil will respond to MY circumstances and because I don't and can't blanket statement or anecdotal evidence my way out of it.....I TEST and FIND the right OCI for the oil I CHOOSE. There is no shortcut but there is blind allegiance. I don't blindly trust anything.    People hear the word 'detergent' and believe that in the context of oil it means the same thing as laundry soap... Only in the most rudimentary way. It's the first additive to give up on you and they are putting less and less with each new API standard. Solvency can be used but it cost. Some unique undisclosed chemistries can be used. Valvoline R & P in example. OEM's haven't an interest in anything they see as limiting market participation. Whatever.
