Recently after driving through the rain I my 4x4 light turned on and stayed on as if it was engages. I am getting code U0422-71 and everything is running normal. I assumed something by the front differential got wet, I unplugged them all and cleaned them. No luck. Thank you in advance!
Edited by D Hendrix
Welcome to the forum! Always post the code definition with the code, as you can see most folks will skip over your post rather than look them up. there are over 18000 possible codes, no one knows them all. Did you try clearing the code?, Disconnecting the battery may reset the module, What vehicle are we working on? some have the switch for the light on the transfer case
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
